Question about Honeywell Truezone HZ311 Zone Control Panel
Where do I put the blue wire on the HZ311 truezone control board for heating?
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
Heat pump will not turn on
I would call an expert, testing needs to be done, but based on what I have seen it may be the control board of the heat pump is defective.
Mar 24, 2017 | Heating & Cooling
Blower MoterElectrialDiagram for a 40,000Furnaces to a Ton1/2 Air conditioner
You will put the red wire from the blower on the terminal marked "heat" on the control board. Black= high speed Red= low speed Yellow/Blue = med low/ med high Hope this helps!
Nov 14, 2012 | Goodman GMS90703BXA Heater
Outside ac unit operates but no blower. Fan "on" does not operate from thermostat. However "heat" works fine furnace and blower. ???
Go to furnace and shut off power, remove blower door compartment. Inside you will find a control board where thermostat wires are connected. Should look something like this:
R-Red Wire= Power
G-Green Wire= Fan
W-White Wire=Heat
Y=Yellow or Blue Wire=Cooling.
It sounds like you have a bad motor speed. So try this:
With Power Still Off, on the same control board there is a terminal usually marked Cool and Heat. There should also be a couple of terminals that are named park. The wires hooked to these are the fan wires..
Exchange the Heat and Cool wires on the terminal board. Put everything back together and try cooling again, if the fan comes on
then you have a burnt out motor speed. Go back to furnace and change
the heat and cool wires around, next if Cooling had the black wire hooked to it, put yellow or blue on Cooling and black to park.
Note: The reason why you put the blower door back on is because it
has a door switch that if not properly seated, you wont be able to power
up anything
Jun 22, 2010 | Heating & Cooling
Reduce blower speed
Motor speeds on the blower are always remember black is high, blue in med. and red is low sometimes blowers are 4 speeds but the main colors are the black blue and red. Now where to change locate the wires coming from blower to a box or control board. control board has setting for heating and cooling speeds for the blower. You might see blue on heating which would be medium speed so take the red off park terminal and change places with the blue. Now if you have a fan control switch it looks like a dail in the middle of the furnace with numbers on the face with pointers set at the numbers. follow the wires from there to the electrical box and open box. find color of blower and switch be sure to cap off the wire you change. Wire nut would be good.
Nov 19, 2008 | Coleman Propane Forced Air Heater...
Honeywell Truezone HZ311 Zone Control Panel Logo
63 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
