Question about Kohler OnCue Generator Management System For 14/20RESA/L & 48RCL
Downloading generator data direct to a PC
I have a Kohler 14/20RESA and would like to download the operating data and fault codes to my PC. Is there a way to do this without buying the On-Cue package. I do not have internet access where the generator is located.
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
No there is no way to do that unless you are a Kohler dealer, and have their service software, which is only available to dealers. It is called KOloader.
Posted on Nov 23, 2013
3 Suggested Answers
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
  • 512 Answers
SOURCE: kohler 30rz62 generator auxiliary fault
Already solved.
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
Kohler 20kw RESA "invalid shutdown" fault
I have a Kohler 14Res and an error Invald Shutdown is indication and the engine is not crancking
Jan 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Problem with kohler 12 kw, showing 38 . 1 code
Normally fault codes are letters? I am not familiar with that code at all. You may have got the control in some configuration setup code 3P0(X) is for raising and lowering the voltage where X is a number from 1-9 for increase
Aug 30, 2012 | Kohler 12 kW Emergency Power System -...
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
Kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Oct 09, 2008 | Kohler 12 kW Emergency Power System -...
Kohler OnCue Generator Management System For 14/20RESA/L & 48RCL Logo
111 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
