Question about Bosch Axxis WFL2090UC
Bosch Axxis WFL 2090 UC stops midcycle and finished and spin lights flash
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
localwonder
  • 6784 Answers
SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Posted on Feb 25, 2009
  • 163 Answers
SOURCE: Bosch WFL 1300. The machine does not finish the
pump could be clogged or bad,or door switch is bad.any codes?
Posted on Mar 06, 2009
smartr10U
  • 1305 Answers
SOURCE: Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
Posted on Dec 14, 2009
  • 4088 Answers
SOURCE: WE HAVE DRAINED THE WATER AND CHECKED THE PUMP CAP
Check to see if the pump itself is operating. Does water run freely from the drain hose when it is lowered below the water level in the machine?
Posted on Dec 19, 2009
I have a 3-year old WFL 2090 Axxis Washing Machine. The door will latch initially, but unlatches during wash cycles and blinking lights come on. It was working fine until the machine was moved. ...
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 15, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Lights come on,door locks ,nothing happens on my bosch 2060 uc washer, sweetie says "it was making a funny noise the last time it was working" while it was spinning . thanks!
the engine maybe has no connection or motor is bad thats why wont start up,check if it belt is good ,if need more info let me knw,if my info was of any help to you please comment me ,thank you.
Sep 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
We have a WFL 2090 UC Bosch Axxis Front end load washer. When we use the Power Wash option, the clothes are soaking wet when the cycle is completed. Are we supposed to use the Power Temp or Power Boost...
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Jun 28, 2009 | Bosch Axxis WFL2090UC
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Mar 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL2090UC Logo
65 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
