Question about Acer Audio Players & Recorders
My neo2001b speakers are not working on my computer
Not working
The speakers wont work when i plug them into the computer so what do i do ?
Try connecting the speakers to another computer, to see if they work at all.
Try connecting a different set of speakers to your computer, to see if your computer is creating sound (not "muted" ???).
May 21, 2011 | Harman Kardon HK595 Computer Speakers
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
Dell speakers w/ HP computer - connection failure
Your HP computer may need the Drivers from the Dell Speakers to work properly.
Jun 19, 2010 | Dell A215 Computer Speakers
Worked last week computer crashes now restored speakers don't work now. another set of speakers work. &35's won't work on a different computer, Powers up clicks when plugged in but no sound /
You said, other speakers worked fine ono that pc right? And the speakers doesn't on other computers? Then surely the speakers are now defective. It might be the wirings or internal parts of the speaker. Check warranty of the speakers, if it is expired, then you have to replace the speakers.
May 25, 2010 | Boston Acoustics BA735 Computer Speakers
A215 speakers are not working....
Connect the speakers to a different computer.
If they still don't work, responsibly recycle them, and buy some new speakers. But, before you do, try the speakers from the different computer in your computer. If they don't work, then it's a problem with your computer, not with your speakers.
Apr 07, 2010 | Dell A215 Computer Speakers
Computer is not recgonizing my speakers?
Check the speakers with any other device. Probably the speakers are not working or if they work fine, connect any other working speaker to your system and check whether if they work or not.
If the other speakers also don't work you probably have a faulty port.
Mar 30, 2010 | Gateway G-MAX2000 2-Piece Multimedia...
Help! Only my right speaker works on my new speakers! Do I need a new sound card?
USB headphones and speakers tend to operate independently of the PC's sound card, but you can determine if your sound card is the problem by plugging the speakers into a different computer. If both speakers work on a different computer, then the problem does lie in the original computer. If so, try a different USB port, especially one that is directly on the computer, not in a usb hub.
If only one speaker works on a different computer, I would troubleshoot the cord that connects the left speaker to the right speaker. Perhaps it is damaged or not connected fully.
Hope that helps.
Oct 15, 2009 | HP USB Powered Speakers . Computer...
My computer speaker is not working
To determine if the speakers are faulty or the computer, plug the speakers into a stereo player. If the sounds come out of both speakers then they are OK and the fault is with the computer/s.
It could be software or hardware fault (ie. the audio card).
Jun 19, 2009 | Jwin Jsp55 Personal Mini Stereo Speaker...
26 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
