Question about Plumbing
My gas goes for approximately 15 seconds and then the flame goes out. The gas botle is fill
  • 16,166 Answers
On what?
Posted on Nov 23, 2013
Flame goes out on gas califont after approx 15 sec. The gas bottle is fill
More information is needed. It probably is a safety device but I am only guessing.
Nov 23, 2013 | Plumbing
Pilot light and burner light and stay lite for approximately 15 sec. and then main gas valve closes. Why?
flame sensor not sensing pilot so doesn't allow main gas valve to open , clean or replace flame sensor and make sure positioned properly.
Nov 17, 2013 | Sunpak S25 Heater
Adjust propane
when turn it on no gas after 10 to 15 second very low gas than slowly goes up than after goes down and up again no great flame
Aug 03, 2013 | Thermador 37 in. SGSX365 Gas Cooktop
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Goodman gmnt060 3b doesn't light
check for 24vac between wires on gas valve about 5-10 seconds after ignitor starts to glow. If ignitor does not glow, check for 120 vac to ignitor after inducer goes on.
First...sequence of operation..power to W, inducer motor gets 120v and starts, 10-15 seconds later, ignitor gets 120v and glows, 5-10 seconds, gas valve gets 24v and opens, after 3-4 seconds the flame sensor approves flame and unit stays on. If this is not happening, it has to be in this sequence. Which ever is not happening and you do have voltage to that component, that component is bad. If you are getting a error code on board after it tries to light, pay attention to the code. if a 1 lock out code, that just means it tried 3 times and did not recognize a flame.
Jan 06, 2010 | Goodman GDS80904BNA Open Flame Heater
Dryer starts then flame goes out in about 15
Check that the lint filter is clean and that the exhaust vent is not clogged. Make sure it is clear all the way to the outlet. If no vent obstruction then the gas valve coils probably need to be replaced.
Sep 21, 2009 | Dryers
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
