Question about Canon imageRUNNER 550 Printer
Ir 550 error e069 - Canon imageRUNNER 550 Printer
3 Suggested Answers
SOURCE: canon ir 7200 error code e069.
The large tr/sep charger on the bed has three pin style contacts at its rear. When you raise the bed the three contacts lift and make contact with leaf springs that press against the charger pins delivery charge to the coronas. These leaf springs become bent back and need to be bent to original position in a triangular configuration.
Posted on Aug 30, 2009
canontech
  • 1219 Answers
SOURCE: e069 problem with my ir 105 tell me what to do?
these means that you have high voltage error, probably in high voltage pcb or somewheare in transfer assy.
These can occure if you mess around with bias settings or if you have fluctuation in your power supply network. The network should be checked first.
Here you go the things that can be faulty also:
- Check if the transfer charging assembly and separation
charging assembly are mounted properly.
- Check if the connector (T701, J723, J730) of the HVDC
PCB is mounted properly and also check the wiring.
- Replace the HV-DC PCB.
- Replace the pre-transfer charging assembly
Hope that helps!
Posted on Aug 20, 2010
Toshiba estudio 167 E051
E051 use to be a false duplex jam on the IR-550 and was always a bad MSW5 switch causing the problem
Sep 20, 2012 | Toshiba Office Equipment & Supplies
I have a Panasonic home theater and am looking for a code that will work with either a starchoice IRC 550 or shaw direct ir/rf 600 remote
http://www.shawdirect.ca/images/support/downloads/550_Manual.pdf
This is the manual for the irc 550 ..and in the manual you have the codes for audio (cd ) which I believe to be the ones you need to use..They are on the end of the manual ..But ! If you read the manual carefully you see that it actually can pick-up the codes automatically if you follow certain programing procedure.described in the manual ..
Jan 28, 2011 | Panasonic Home Theater System System
E069 problem with my ir 105 tell me what to do?
Hope that helps!
Aug 19, 2010 | Canon Office Equipment & Supplies
E000069-000 Imagerunner 8500
An E069 code indicates a fault with the transfer charging assembly. TP02-015 lists certain areas that should be checked to prevent this code. Additionally, a bias voltage is applied to the fuser assembly and the paper feeder guide and if this bias voltage shorts to the frame it will cause E069 codes.
Mar 14, 2010 | Canon imageRUNNER C3220 Color Copier
How do you set up a harmony 550 to be able to use the record on a dvr
Click 'Learn IR' next to the icon for your DVR in the software, learn the command, then assign the command to a button in one of your Watch TV Activities.
Feb 11, 2010 | Logitech Harmony 550 Remote Control
Ir 550 error code e800
Check the fan motors in the feed section and the power supply section.
Oct 23, 2009 | Canon Office Equipment & Supplies
Canon ir 7200 error code e069. Replaced the chargers but the same thing persist.
Aug 09, 2009 | Canon imageRUNNER 7200 Copier
Canon 500IR - Error Code E000602 0004
Is your copier a IR-5000 or a IR-550? It dose not really matter - the code means that the hard drive in the copier is not "Booting Up" correctly. Are you a service tech? If so, you can try to reseat the boot rom and clean the contacts with rubbing alcohol. After you turn the copier Off and then back On after you reinstall the boot rom. You can also try to do a HD chk in service mode. You will most likely have to replace the "HD" and have it "Flashed" to your copier configuration. Good Luck....
Feb 17, 2009 | Canon imageRUNNER 5000 Copier
I recieved Code E069 in my machine
hi
error E069 is high voltage leakage?clean transfer unit and separation corona,
Jan 15, 2009 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 550 Printer Logo
20 people viewed this question
old marine
old marine
