Question about GE Ovens
Error code f76 - GE Ovens
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
Electrolux oven error code f130.what to do?
Hey Luciano, I appreciate your inquiry!
From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
Nov 29, 2015 | Electrolux Ovens
I have error F76 and the oven is beeping.
MAke and model needed to find error codes
Jan 30, 2015 | Ovens
Is there a sight to find frigidaire built in oven error codes
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand you are seeking a site that provides a listing of error codes on your Frigidaire oven. This information is very rare to find. Is your oven receiving an error code? If so, may I have the error code and with this information I'll be more than happy to help you narrow down the possibilities of the code. Thank you!
Aug 02, 2014 | Frigidaire Ovens
F76 error code on ge oven
One of the most common problems with GE electric built in ovens is the error code "F7? shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4? nut driver and a Phillips screwdriver. - See more at: http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/#sthash.pVUT3Nzb.dpuf
Oct 14, 2013 | GE Ovens
Electrolux oven error code f 136...what to do?
Hello - Could it possibly be error code F13 or F36? According to my research this manufacturer does not have an error code F136. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and see if the error code clears. If it proves to be ineffective, contact a professional to move forward accurately to properly diagnose the unit.
Nov 25, 2012 | Ovens
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Ovens Logo
139 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
