Question about Craftsman 370200 Motor
Wiring diagram which leads connect where.
How do I reconnect the capacitor?
Not easy to explain. The capacitor is split, it has two values, or like two capacitors connected internally with a center tap between them. Two capacitance values, maybe 5uf and 20uf, the lower value for the fan motor and the higher for the compressor, with terminals C-common, F-fan, M-compressor.
Capacitor terminal C is the center tap and that takes 3 connections, line (power) - fan line common to capacitor, and Compressor line common to capacitor. Notice the fan and compressor have a power line not common to capacitor, just power line.
Capacitor terminal F has one wire connecting to Fan terminal C, fan may have three or four terminal writes, two for power with one power being common to capacitor connection and the other power alone, two power connection wire leads. Fan motor third line is capacitor, connects to the capacitor alone. Four wire configuration fan motor is not likely your needs. Omit or ask again for further explanation.
Compressor is similar to fan, only with a capacitance value higher than for tha fan motor. Two power leads, one straight power, the other power lead connects to the capacitor power. The third compressor lead connects alone to the capacitor.
The with is to draw a diagram and level the colors of each lead and terminal lavels too. The motors nameplate may indicate wire color code, the a-c nameplate wiring diagram may be present in the control wron wiring compartment, the goal is to find clues or to trace each wire and verify what they connect or do, take notes on your drawing.
Basically the motor has three terminals, L1 - L2 - C, or C- S-R (Common, Start,Run)
Jul 14, 2015 | Maytag Heating & Cooling
Solenoid wiring diagram
its easy dont over think it .
you have two heavy leads & one or two light leads
the two heavy leads go to the two heavy termials in any order
the two light leads to small terimals in any order ,if its only got one small lead ,you know where it goes ok have a go its only a big switch to connect the two heavy leads togeather as the tiny little starter button could not carry the load hope this helps
Apr 18, 2014 | 2006 Suzuki Boulevard C50
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
Replaced an old Magnetek century two speed with a AO smith century two speed. Hooked the wires up the same but unable to get the motor to operate in the high speed mode, suggestions!
Each motor will have wiring diagram on label.
Compare diagram on old motor with new motor.
WIRE COLORS VARY
Which 2-speed timer do you have on the circuit?
Wire lead from NO terminal connects to High speed.
Wire lead from NC terminal connects to Low speed
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Oct 23, 2012 | Pool & Spa
Wiring diagram battery pack aspire 5580
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 5580 Notebook
I need the actual wiring diagram for the Intermatic LC4535. The enclosed paperwork that is included shows a neutral connection that is vague on the 480 volt connections.
LC453r is rated 480V.
The drawing shows the photo eye connected to lamp that is also connected to neutral wire.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/photo%20controls/lc4535%20-%20english.ashx
Your 480V has 2 hot leads going to 480V Load.
Select one hot lead to install photo eye.
Connect selected hot lead to photo-eye black wire. Run photo-eye red wire to Load.
Connect photo-eye white wire to Neutral. Without a neutral wire, this photo eye will not operate.
Aug 03, 2011 | Intermatic LC4535 Photo Cell Control 480 V...
I want to hook up a slim sub for my truck using this amp. how can I do that? Because this amp plays everything not just the bass
You will need to connect the low level input leads from the head unit to the amplifier (they are RCA cables). If there are no low level leads from the head unit, you will need to connect the wires from the speakers directly into the high level inputs using a wiring harness which should have been included with the amp. It should include a wiring diagram. You will need to use that diagram in conjunction with the truck's wiring diagram in order to know which wires to connect. They are color coded and once you have the vehicle wiring diagram (which can be downloaded by searching for it on google.com), it should be easy to determine which wires to connect.
Mar 04, 2011 | Audiovox AMP610 Car Audio Amplifier
Wiring diagram for electricmotor with capacitor
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Apr 01, 2010 | Heating & Cooling
Need a wiring diagram to connect a photocell to LS 70 sodium fixture
please give me wiring diagram to connet photocel with auto and manual switch
Sep 26, 2009 | Cooper Wiring Devices 1301-7LTWBOX LIGHTED...
Motor for my vulcan convection range was disconnected for moving by previous owner. There are 4 leads on motor, red and 2 black, and only one red lead (marked #1) still has label. The stove leads are still...
Red wires are usually the in and out for the centrifugal switch. the black wire that goes to the panel inside the motor is likely the 120 connection, the panel is the start switch for the start winding of the motor. This black wire should be connected to the 120 (from inside oven) and one of the red wires (three wires together). The other black wire of the motor should be connected to nuetral (you will have to determine which of the wires you have left coming from the oven is nuetral) the other red wire should be connected to the wire that feeds back into the oven for gas valve/thermostat controls (you may be able to trace this wire by hand to see if it goes to thermostat and gas valves). Hope this helps.
May 03, 2009 | Vulcan 36LC Gas Kitchen Range
Craftsman 370200 Motor Logo
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
