Question about Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool
How to remove chuck - Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool
  • 3,961 Answers
Check first to see if there is a screw or allen head bolt deep down in the centre of the chuck, securing it against loosening due to vibration. The trouble is the head of such a screw often gets damaged, making it difficult to remove.
Then the chuck itself will be screwed onto the spindle with a RH thread, so it tightens in normal use. It may be very tight, so insert a tight fitting steel stub into the chuck key hole, and hit it sharply.
If it is a keyless chuck, there should be a slot there somewhere to fit a piece of metal into so you can hit it. Use a piece of soft steel or copper if you have it.
Posted on Nov 23, 2013
How to remove a bent chuck from a Ryobi DP101 bench drill press
look inside the center of the chuck... if the is a bold inside, remove it. then place the short side of a 3/8" allen key into the chuck and tighten the chuck... then smack the allen key from the side with a hammer the same direction as forward rotation...
Oct 25, 2013 | Drills
We have a chuck that got jammedand broken, is it possible to remove the chuck only and replace it or do u only get the whole front section with chuck. And if the chuck can be removed, how do u remove it....
With the chuck open as far as possible, look within the jaws of the chuck for a bolt or screw head that attaches the chuck to the shaft. Remove the bolt/screw and remove the chuck. Some chucks can also be screwed onto the shaft, so look for signs of threads at the base of the chuck. Otherwise, once the bolt/screw is removed, tap along the outside around the chuck with a plastic hammer to loosen the chuck. Penetrating oil will help.
Take your chuck with you to a "big box" type hardware store, where a replacement should be available. Any well stocked hardware store should be able to help you. I have found that the somewhat smaller hardware stores are usually staffed with knowledgeable persons, and getting a replacement ordered is easier. One is more likely to be stocked in the larger stores.
The name brand of the chuck isn't as important for a replacement as is the correct shaft size and style of fit.
Best regards, --W/D--
Jun 15, 2011 | Chicago Pneumatic RP9790 STANDARD GRIP...
How to change the chuck on 18 volt cordless drills
Set the drill to reverse. Hold the chuck, press the trigger and open the drills chuck to it wide open position. Now,, take the correct size allen wrench and insert it into the back of the chuck to remove the screw. Turn the screw clockwise to remove it. Notice I said clockwise, just the opposite of what you might think. Hold the chuck with your hand or a pair of large vise grips and press the trigger to unscrew the chuck from the drill. Rotate it counterclockwise to remove it from the drill. Reverse the procedure to install the new chuck.
Mar 10, 2011 | Dewalt 18 Volt Compact Drill Kit
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How can I remove the chuck of a KR 110 hammer drill. The LH threaded internal screw has been removed but the chuck remains firmly fixed. I want to replace the existing chuck with a Jacob's type keyed...
The chuck is screwed on with RH threads. Lock the shaft and insert your chuck key into one of the key holes. using a plastic or wooden mallet give it a sharp tap in the right direction, this should free it up so that you can remove it. When you reinstall the new chuck us the same method to tighten the new chuck.
Jun 09, 2010 | Electrical Supplies
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Jan 01, 2009 | Makita 6304LR 1/2" Chuck Electric Drills
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool Logo
55 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
