Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Want to change keyless chuck
No allen screw inside chuck
    Habit-Forming:
  • 188 Answers
If your wanting the sleeve, #12 on breakdown, then search the part # as There are other places that still have it. http://www.ereplacementparts.com/dewalt-dw056-type-18v-cordless-impact-driver-parts-c-1009_9591_2845.html
Posted on Dec 29, 2013
  • 313 Answers
SOURCE: drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Posted on Jun 02, 2008
  • 313 Answers
SOURCE: How do you change a
position the drill to speed one & drill mode.u need a allen key then clamp it the chuck jaw close & tight. hit the allen key with hammer counter clockwise until its loosen. may have to do it any several times.
Posted on Aug 12, 2008
  • 90 Answers
SOURCE: Is it a torx or
don't know the sizes for the screw but it is the wrong way threads. when you get that out you need a very large allen wrench in the chuck and tight. lay the drill body on a work bench and hit the allen wrench hard to break it loose. it unscres normally.
Posted on Sep 01, 2010
puertobori
  • 7733 Answers
SOURCE: My Dewalt 1/2" Drill (DW236) keyless chuck is
Look at eReplacementParts.com and the parts diagrams.
Posted on Nov 08, 2010
  • 885 Answers
SOURCE: Hi i took the screw out of chuck put allen wrench
The chuck is put on extremely tight even the ones with a set screw. You have to hit the allen wrench HARD, almost to the point to where you think you may break it. I have also had good results using an air hammer with an allen socket. Just make sure you're turning it in the opposite direction the screw turned coming out.
Posted on Dec 23, 2010
How do i remove a keyless chuck from a Craftsman 19.2 volt 2-speed drill
Inside the chuck you will find a screw (probably torx) this is a left hand screw (Remove clockwise)
Insert a 1/2" allen key into the chuck and using a hammer strike it to spin the chuck off (Standard thread - Counter-clockwise)
Mar 09, 2015 | Craftsman Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
Hello, how do I change the drill bit
There are key and keyless drills and some have a quick connect spring device. To change the unplug then chuck open it all way & insert screwdriver. Most chuck screws are left handed (turn right to loosen) some drills have no screw inside the chuck. Insert a large allen wrench and tighten next hit the allen wrench counter clockwise to remove the drill chuck.
Jan 16, 2011 | Drills
How to fit a bosch keyless chuck
remove the old one. check inside the throat of the chuck to see if it has a screw. if it does turn it left to right. if no screw good. take a very large allen wrench and place in chuck tighten it. place it on a flat surface, bench edge, where the chuck is free. lift the allen wrench up higher than level and take a large hammer and hit it down hard. this will break it loose from the spindle. when you go back with the new one put never seize or grease on it some it won't bind. next time you change it it will come off easier.
Aug 05, 2010 | Bosch 13624 24V Cordless Hammer Drills
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Having trouble removing keyless chuck from 18V DC759
Inside of chuck you have a screw, remove screw then tighten an big allen wrench into chuck, short side in, then hold drill and hit allen wrench with a hammer quickly, should break chuck free.
Jun 19, 2009 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck removal
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Sep 22, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Drill chuck swap
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
140 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
