Question about Compaq Computers & Internet
Monitor blacks out on compaq computer - Compaq Computers & Internet
  • 126 Answers
There will 2 possible solutions.
If logo not appears, then most probably, the display is faulty.
if you are getting a logo, then try to perform the following steps :
1. take out the battery and make sure that nothing is connected to the laptop (not even charger).
while battery is out, press and hold the power button for at least 15-20 seconds to remove the static.
once you done with that, place the battery back to its place and as soon as you press the power button, start pressing F8 key on the keyboard.
if you get advanced boot options, then select Last Known Good Configuration using your keypad as mouse will not work and then check
if you didn't get the advanced boot options, then see if you can get in the BIOS.
if you are able to enter in the BIOS, the load BIOS as default and then check.
If you are not able to get the BIOS, then the computer is died.
You can enter in the BIOS by pressing F2 or Del key on the keyboard at startup.
Posted on Nov 23, 2013
Compaq WF1907 19" monitor backlights are on, but
Check the monitor on another computer to verify if using correct setting for this monitor will allow a clear image to be displayed.
In windows 7, the monitor should be detected and installed automatically.
What version of windows are you using?
Dec 25, 2010 | HP Compaq WF1907 Monitor
My Compaq s1922a monitor goes black right in the middle of me working on the computer. What could be causing this?
Try the monitor on another computer to see if it does the same thing with another graphics card. If it does, then the monitor is bad.
Aug 19, 2010 | Compaq Computers & Internet
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
Compaq Monitor 7020 adjusting...
Try monitor on another PC / laptop, if still no go it will be either faulty cable or monitor.If it works then the video card is faulty or needs to be reset in the slot.....you haven't said if its a PC / laptop.
its pc not laptop,but when i use other monitor for that pc it works
Jan 24, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
How to fix black stripe on left side of monitor?
The black stripe is there because the connections to those pixel rows inside the lcd panel are interrupted. This is unfixable. Buy a new monitor.
Oct 30, 2009 | Compaq FP 7020 17" Flat Panel LCD Monitor
My monitor, once i start my computer then monitor start to flick and became black screen, what is the problem please let me konw any thing i can do for my monitor. modle no- compaq fp 5315
its a risky for you to open the monitor and repair its power supply, coz its your monitor's power supply prob..
please contact with warranty providers.
good luck
shafky
Jun 19, 2009 | HP Compaq FP5315 15" LCD Monitor
Compaq TFT5010 went black.
Good, I have seen this before. Thanks for asking at Fixya!
Mar 31, 2009 | Compaq TFT5010R 15" LCD Monitor
Removing the case for a Compaq 7020 17 in LCD monitor
The case has 2 plastic snaps en each side as well as 3 snaps at the top
Use a flat-head screwdriver in the **** between the gray and black plastic. Twist the gray plastic away from the black plastic, and this will snap the part appart
Apr 24, 2008 | Compaq FP 7020 17" Flat Panel LCD Monitor
Black bar at the end of my compaq v700 monitor
the monitor is bad.
its CRT monitor.
only googling find relic schmematics
you do know right the 2nd anode is at 15,000 volts right?
and that is lethal , right>?
zero 2nd chances.
no photos by you, so no answers ever possible on CRTs.
it works like old TVs did, only uses, different cathode drive
called DATA. (no tuner or radios inside, like TV)
the lines are my guess, caps bad in the Horizontal or vertical drivers for the yoke coils.
do not get killed playing with HV ok?
Aug 29, 2017 | Compaq V700 17" CRT Monitor
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
