Question about Panasonic PV-27DF64 27 in. TV/DVD Combo
Sb350 spongebob password
I do not know my password for movie blocks. please help
0 characters
1 Points
I have sb350 tv for my kid and i lost the parental on the dvd it wont play them how do i reset it
You have listed it as an Emerson.
Google the brand/model number with the words owner manual and if that does not work try finding the customer service toll free number for whoever made it (brand)
Mar 15, 2012 | Emerson SB350 13 in. TV/DVD Combo
I have a sponge bob emerson sb350 the parental control in locked for dvd's how do i unlock it. bought tv at rummage sale they didn't know the code
Could be anything,not possible,only tries reset every setting.Ask Emerson for how to unlock.Go to their website might show how to reset codes.
Dec 12, 2009 | Emerson SB350 13 in. TV/DVD Combo
Emerson made Spongebob Squarebob tv/dvd REMOTE CONTROL
Yes, It is possible that the remote eye sensor was not connected at all & not tested. Usually done when the machine was tested & or repaired and not put back together properly.
If u know how to open (power off!! please) and get to the front where the 'eye' should be, just see if the wire is connected to the front end board., sometimes the "eye" is connected directly to the board, Then see if "eye" is blocked.
May 27, 2008 | Combination Televisions
Unable to get some NR movies to play even though I have unblocked NR material
The parental code is :
When the parental block comes up hit play, then type in the code and hit play again.  It should be all set.
Mar 28, 2008 | Disney Princess TV/DVD Combo
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Combination Televisions
Emerson sb350 ( spongebob dvd combo )
I had the same problem.I fixed it by unpluging the tv.Then while holding in the power button I plugged it back in,still holding in the power button for twenty seconds.That fixed it.I read somewhere you could reset a Sony that way so I gave it a try and it worked.I also put a cd cleaning disk in it because it was saying "wrong disk" and that fixed that problem.Good Luck
Aug 10, 2007 | Emerson SB350 13 in. TV/DVD Combo
TV DVD VHS combo 27 inch
this problems its no posibil to rezolv home becous is nesesari technology of laborator
Apr 14, 2007 | Emerson SB350 13 in. TV/DVD Combo
DVD tray will not eject
go to the any depanator and help to zero(.)settyng your dvd
Nov 28, 2006 | Emerson SB350 13 in. TV/DVD Combo
Emerson sb350 parentel control
Try these codes 0000, 1234, 000000,123456. If these codes above doesn't work, check the manual. good luck
Aug 30, 2006 | Emerson SB350 13 in. TV/DVD Combo
Panasonic PV-27DF64 27 in. TV/DVD Combo Logo
221 people viewed this question
Top Panasonic Combination Televisions Experts
Jaime Hernandez
Are you a Panasonic Combination Television Expert? Answer questions, earn points and help others
