Question about Moultrie MFH-DGS-200 Digital Camera
Camera on and SD working - but not taking pictures
I borrowed a friend's mfh-dgs-d65ir and it isn't taking pictures. The SD chips is fine. The battery says 77% and two days in a row, the only photos are of me setting it up. Then it goes to sleep and doesn't seem to wake up. I've seen 4 deer within 10 yards of it.
  • Steve C
    Steve C Nov 23, 2013
    I changed the batteries and put it into IR test mode. The movement sensor is only good for ~10 feet. Glad I only borrowed this and didn't buy one.
  • Steve C
    Steve C Nov 26, 2013
    Thanks for the response. For the 65IR, I did not see a setting either in the menu or in the manual for setting AF to any distance. Where would I find that?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Check flash is not obscured by the case
Check AF is set to infinity or [set by range]
Ensure target is within AF zone...might be aiming too low in order for it to register movement.
Posted on Nov 26, 2013
Testimonial: "Thanks for the response. I the 65IR, I did not see a setting either in the menu or in the manual for setting AF to any distance. Where would I find that?"
Note if sd card is installed is on the screen wont advance past that DGS 160. I have tried different SD card, hard booted, changed batteries, when I plug into computer interface, it doesn't recognize ...
Do you mean the DGS I-60? What size memory card are you using? The I-60 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 15, 2013 | Moultrie MFH-DGS-200 Digital Camera
I turn on the camera and it says SD LOCKED. What do I do?
open the sd slot on camera, take out sd card and there should be a little slider on sd card, slide it the opposite way, sd card should now be unlocked. shouldnt get the same message again.
Oct 26, 2011 | Moultrie MFH-DGS-100V2 Digital Camera
My camera powers up but I can't get it to take any photos I don't have the manual either - and we have never used it I bought it new
having trouble getting camera powered up. Need to pull batteries and push button then it restarts, but wont take pictures. Like its jambed up. ive tried different sd cards also.
Oct 02, 2010 | Moultrie MFH-DGS-200 Digital Camera
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
I-40 camera will not go to picture mode and start taking pictures
Have you done the time/date setup? Online manual says it goes auto after 4 minutes, but perhaps the date/time need to be setup first? Online manual here in case you lost your book :)
http://images.ebsco.com/pob/moultrie/catalog/dgs-i40-user-manual-compressed.pdf
be patient, it takes a bit to load
Aug 26, 2009 | Moultrie MFH-DGS-200 Digital Camera
Need help seting up camera
Sd locked means your card is locked so that you cannot delete pictures.remove card & slide locking tab down-the tab is on the edge of the card.hope this helps
Jan 25, 2009 | Moultrie MFH-DGS-100 Digital Camera
Buy MFH-DGS-100v2 (new or used)?
Jason I have a Moultrie MFH-DGS-100v2 I don't use. I've had it about two years, but haven't been able to put much time into off-season scouting. Contact me at russmanc17@yahoo.com if you are still interested in purchasing one.
Rusty
Oct 24, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Sd card locked
Don't worry guys if you can change the tire on yout car you can fix the SD CARD LOCKED PROBLEM.
You will need a set of mini phillips screwdrivers (everyone has a set in there box)
Open camera door note the tiny scews I think 4~5 of them also two screws that hold the back-up watch battery. remove all of them.
there are more screw inside just take your time and find them.
Carefully lift out the guts and you will see a set of contacts along the side of the SD CARD SLOT.
You can slide your sd card in and out of the slot and note that the contact point open and close.
the reason your card reads LOCKED is because the contact points are dirty I used fine sandpaper
to clean them up after I done this the camera worked perfectly again. The whole job took all of 15 min to preform.
Aug 26, 2008 | Moultrie MFH-DGS-100 Digital Camera
Moultrie MFH-DGS-200 Digital Camera Logo
281 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
