Question about Garden
Model 8r6 point gap - Garden
What is the ignition point gap?
In older engines with traditional points-condenser-coil ignition systems the dwell if the ignition was set by the gap between the points. The points act like a switch that opens and closes the circuit of the primary side of the ignition coil.
All later engines use electronic ignition that do not require points.
Mar 28, 2016 | Cars & Trucks
Looking for the point gap
A lot of the manuals are online for free...try putting in make/model number and manual to try to find, also you can put in make/model point gap in your search engine, works a lot of the time.
Sep 02, 2015 | Boating
Points gap
Hi Joe
Use a business card, to adjust the points...it is approx 18-20 thousands.
Bud
Apr 23, 2013 | Echo Garden
Vw caddy rabbit 1.6 point gap spark plug gap?
Most point gaps are between .003 and .005 I would try a plug gap of 0.030 to start. I would be happy to give you exacts if you provide a year make and model.
Mar 18, 2013 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Adjusting the points
With points cover off,slowly bring engine to the highest point on the points cam.Its easiest to do this with the spark plug out,and slowly spin the engine with the kick start. Once you get it to the highest point on the points cam,the points should be "open". Insert feeler gauges untill you find the correct one...(it should have slight resistance). The check what the recommended gap is for that model. After finding the recomended gap,use the feeler gauge that matches the recomended gap,and isert between the points. There should be two screws,one on each end of the points. Loosen those two screws,and the body of the point will move,one way to "open": the gap,the other to "close" the gap. With feeler gauge between the points contact,close untill you feel slight resistance when moving the gauge back and forth,and tighten the set screws on the points body.
Aug 31, 2012 | 1973 Honda CB 100
1964 292 engine how to set the points gap what is involved
There are feeler gauges (extremely thin) to adjust the points gap. First find the proper gap for your model vehicle, and then purchase a gauge. these gauges have something like 10 different thicknesses, for different points, so make sure it includes the exact gap that you need. I remember in my youth adjusting the gap with cigarette wrapper paper, it seemed to have the proper thickness to get you out of dodge. Also remember that you have to rotate the engine until the points are in the open position, in order to adjust them.
Aug 03, 2010 | Chevrolet 1500 Cars & Trucks
I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP FOR A POLAN CHAINSAW MODEL # 2375
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
