Question about Toshiba Satellite L505DS6957 PC Notebook
No key board in bios
No keypad in bios
    Scholar:
  • 46 Answers
Try hooking up a USB keyboard and seeing if it works.
If it does work, the keyboard on the laptop may need to be replaced, but I would first check if the cables are plugged in securely.
This can be tedious to do, but the cabling for laptop keyboards are very finicky, and the slightest bump while installing a keyboard can dislodge the connection enough that you might get this error message.
If this is the case when you try to boot the PC completely the POST process may stop saying it cannot detect a keyboard.
If you mean specifically that the keyboard doesn't work while in the BIOS, but works everywhere else such as in windows.
You may need to install a BIOS update for the laptop mainboard.
Checking the manufacturer's site for the most recent BIOS update might fix the no keyboard in BIOS issue.
BIOS updates are not for the faint of heart, they sometimes can be intimidating to do; And you will want to take some caution when doing so.
Posted on Dec 09, 2013
Cant get the numbers to work on right side of key board
Numlocks turned on in your BIOS.
Or just a keypad issue where it states NUM LOCK
You may have to consult your owners manual to find out what key sequence is used to get into it.
Be very careful in the BIOS.
Apr 13, 2015 | Computers & Internet
Well, my Netbook scrolls down randomly. Either up or down. No matter what I do it won't stop, I usually bang on the directional keys and it does stop for a short period. I really don't want to keep...
Sticky keys might be the problems.
1.Press SHIFT 5 times repeatedly
2.Cleanup the touchpad on the right corners ( unit OFF )
3.Seem the PgUp and PgDn keys STICKY >>> try clean it with a dry soft brush
Aug 16, 2011 | HP Mini 1000 Netbook
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 30, 2011 | Ovens
Keypad in w350i not working...how 2 repair tat
Remove the external key pad and press the internal keypad on the phone board directly, may be the external key pad rubber is not contacting the one on the phone board.
Or you can loose the phone, and clean the internal part of the key pad. There might be dust on it, you could also use this medium to service your phone. If it does not work after all these, then I think you have to change the key pad completely.
I wish you the best.
Nov 23, 2009 | Computers & Internet
On rbd275pdb12 what is the code E6 F2 means
HI, this is referring to the cancel key on your key pad. It is stuck open. follow the procedure below.
Oct 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Vista and Ventrilo
this motherboard have till windows xp support and u have install vista but still no issu u have to download new bios updat from asus site for this board and get new updat of bios and once format & reinstall vista os again
Thanks
Jul 25, 2009 | ASUS M2N-E SLi Motherboard
Oven preoblem kitchenaid ykers807sp "err f2e1 stuck/shorted key " showing
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
Jul 17, 2009 | KitchenAid Architect Series KEBC107KSS...
Right hand side of key board displays numbers
Your bios probably is set to use the embedded keypad when the numlock is on. you can set it to numbers only when you press the FN key
Feb 18, 2009 | Dell Latitude C640 Notebook
Range flashing code f2eo
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Dec 13, 2008 | Kitchen Ranges
Toshiba Satellite L505DS6957 PC Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
