Question about Refrigerators
I bought a new fridge in August and it sqeals every time the motor runs the warranty repairman says it will get better as it gets older, is this true?toll free number
    Problem Solver:
  • 16 Answers
No its not true get a new repairman
Posted on Nov 25, 2013
4 Suggested Answers
  • 531 Answers
SOURCE: Amana refrigerator too warm, freezer too cold
the damper control is not working let me tell you what to do the air that comes from the freezer block if you can get to the damper you will see it have a get rool a piece of paper between the body of damper and the get flap and have it open if the refrigerator side start cooling is the damper control i am sure about that is the damper control
Posted on Apr 01, 2009
woodchuck789
  • 4059 Answers
SOURCE: refrigerator does not get cold, motor is running,
Well, that's great for you since the sealed system is cover with a five year parts and labor warranty. Call a local Frigidaire certified repairman and tell him the situation.
Posted on Aug 09, 2009
  • 4793 Answers
SOURCE: we have a RSH1DBRS American
depends what country you are in,if in the UK, then you have the sale of goods act.(suitable for the purpose,regardless of time warranty)why dont you email samsung uk.i am sure they would not like a stressed out housePERSON.lol.
Posted on Nov 02, 2010
My machine motor will run but the needle won't move up and down unless I manually move it. I can hear the motor running but nothing is moving on the machine. I've tried checking everything and am out of...
Its sound like the belt is slipping, maybe if its under warranty try to call the place that sold it to you. Most motor belts are accessable for adjustment and servicing. Its on the right side under the handwheel.
Jan 15, 2011 | Singer Sewing Machines
We have a RSH1DBRS American style fridge freezer that an engineer has repeatedly been called out to since June 2010 then August now we have been told that because the problem still exists the engineer...
Nov 02, 2010 | Samsung Refrigerators
My freezer is frosting excessively and my fridge is warm. What should I do?
You have a leak in your freon (or whatever gas they use), It is expensive because they have to run a dye to find the leak. Try to find out first by phone, because you may be better off buying a new fridge unless it is under warranty, I am speaking from experience, I just paid $800 for a new compressor and recharge the system. If, I had known it was going to be that expensive, I would have ditched thing and bought new one with a warranty,.
Oct 15, 2010 | Sewing Machines
I bought the fridge in 2006. In 2008 it began making a loud vibrating noise. Repairman replaced the fan motor blade.Took 30 days to get part! It was never quite right after that. Had problems with defrost...
Could all be in the fan motor. If it's bad again, I would change the motor and blade. Then fire it back up and test for correct cycling.
That may take a week of running until you get a true picture of whats happening, but they do have a lot of trouble with the motherboard./
Jan 17, 2010 | GE Refrigerators
My 2003 kenmore elite french door fridge made noise for several days, then died. Repairman said it was compressor...expensive repair, so I bought new fridge. Old fridge came back to life 48 hours after...
I bet the bearings in your compressor are bad. The compressor will run and heat up but after getting hot it won't always restart. Most of the time it happens with Tecumseh compressors.
Sep 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Jun 02, 2009 | Samsung RB215LASH
Apr 01, 2009 | Amana Easy Reach Plus ABR2527FES Stainless...
Flickering screen
If you bought it new in this last August, don't put up with it but get it fixed under the warranty. That is what warranties are for.
Jan 23, 2009 | Gateway FPD1975W 19" LCD Monitor
LG 37 inch Flat Panel Loses picture
Take a camcorder and capture it, that should be enough proof that it's failing often enough to be repair right. When the picture goes out, can you see it dimly if you take a flash light to the screen? It might be a bad inverter.
Apr 25, 2008 | Televison & Video
Samsung RS2530BSH side by side stoped cooling
You have most likely experienced defrost issues with this fridge in the past. If not...you will...I have had nothing but trouble with this since I bought it. OK...hold down the ICE TYPE button at the same time as the FILTER RESET button for 10 seconds. The fridge will power back on and begin to cool again. Now, this is not a quick fix, but a diagnostic test!! Your fridge could power back off and do the same thing in 12 hours. If this happens, notice and take note of the indication lights on the front. I have defrosted my fridge many times and then out of nowhere it did this too. The problem is most likely the defrost sensor and has most likely never worked correctly in the first place; otherwise, there would not be a need to defrost manually. (I think the part should have been recalled!!) Anyway, this will give you the information that you need to tell the repairman. Most likely, the defrost system (sensor) will need to be changed out at a cost of approximately $200-300 plus labor, but still cheaper than a new fridge. This method may be used over again to keep your food from spoiling until you can get a repairman out. You may have difficulty in finding a repairman and most companies have gone to servicing only American made products (due to the parts being hard to get). I recommend a Good Housekeeping dealer!!! Otherwise, you can contact Samsung at 1-800-Samsung and they can refer you to someone in your area who can fix your fridge.
Hope this helps!!
Mar 04, 2008 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
