Question about Dryers
Speed Queen dryer not working after I pressed in the knob while turning!!
    Sergeant:
  • 446 Answers
Check your circuit breakers it may have tripped
Posted on Nov 23, 2013
5 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: coin operated speed queen gas dryer works some
Check the coils on the gas valve. Sounds like an intermittent one. Eric
Posted on Jun 20, 2009
canbruce75
  • 1776 Answers
SOURCE: LPG kit for Speed Queen 30XG gas dryer
You should be able to convert it over. Check out the link that I am providing. It's information on the conversion process and what it entails. Hope this helped and best wishes.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Posted on Sep 06, 2009
rogrrabbit
  • 986 Answers
SOURCE: Dryer doesn't throw hot air
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
Testimonial: "Thank you so much you saved me time and money"
  • 77 Answers
SOURCE: dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
Posted on Mar 12, 2010
I have a speed queen electric dryer mod AES68AWF. i was in a hurry&turned the timer knob while it was running. it sparked a little & then went off. can it be fixed?
Should not have hurt anything by doing this as long as knob was turned clockwise while doing so. Did it spark around the knob itself. Stan
Apr 01, 2017 | Speed Queen Dryers
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
I have a speed queen gas dryer. do i have to
It would be safest to turn off the gas supply. You should have a gas **** in line for this purpose.
Aug 29, 2009 | Speed Queen Dryers
Speedqueen Commercial Dryer trips electricity
there is moisture in there and it trips off the safety switch. some refridgerator points are not connected to the safety switch, this can dry out the moisture and this safety switch is there to save lives, don't touch the appliance when on and do at own risk because i am covering myself, you shouldn't have any problems but i have to cover myself. there is leakage from probably the element to earth which is the reason i sugest to try and dry it out. your element could be blown as well? you might need a sparkyto replace element
Jun 01, 2009 | Speed Queen AES68AWF Dryer
Dryer Does not turn on when pushing the button
hello is the door making the switch if thats ok check wires see if they are loose if thats ok . at the bottom of the dryer next to the motor theres a part called a capacitor its got 2 wires coming off it. this can stop the dryer working.i hope its works
shaun
Jan 29, 2009 | Speed Queen Dryers
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
