Question about Evolution Spas Ventura 90-jet, 6-Person Spas, Hot Tube, Hot Tubs,Patio Ideas,New
A hose fitting is spraying water
A hose that is loose with strange end fitting is spraying water inside the cabinet. What do I do to fix it? What is the hose for?
  • 1,631 Answers
Need to help us more: the definitions you used are too generic - "Hose; Strange End Fitting; & What is it for" doesn't provide any help to identify so that we can assist. Pictures always help.
Posted on Jan 27, 2014
Air is on all the time
I assume you mean the air pump for the the rear air shocks. Somewhere in the airlines or fittings you'll find the leak.
Just follow from end to end. If need be, fix up a spray bottle of dishwashing liquid & water. Spray the air hose & fittings liberally, the detergent will produce bubbles at the problem area if you can't hear it leaking.
Dec 30, 2013 | 1992 Cadillac DeVille
Water leaking from hose inside washing machine casing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jul 02, 2012 | GE Washing Machines
How do i install a motor on a blanco dishwasher bfdwc65
Hi.
The parts' arrangement is similar to several Whirlpool model. The pump motor is located under the bottom place and it is accessed removing the front kick panel (in front at the bottom).
Here a movie showing the procedure on a Whirlpool similar to your Blanco. I also tried to describe the procedure below. Check also the parts diagram for your model at the end of this comment. Sometimes it is not necessary to lean the appliance on one side, depending on how you can reach pump motor and hoses. See movie and description.
To remove the old motor you need to:
  1. Disconnect power.
  2. Move appliance forward.
  3. Disconnect drain and inlet hoses and remove water from tub (if any).
  4. Remove baskets or anything else from inside the machine.
  5. Remove spray arms and remove the assembly at the bottom of the machine.
  6. Put some clothes or towels on floor and lean the machine on one side.Water will leak out, the clothes will help here.
  7. Take the kick panel in front off.
  8. Undo the screws that hold the pump to the machine cabinet.
  9. Use a flat screwdriver to loose the clip holding the hoses. Loose the clip but do not open it completely (it will help later).
  10. Pull off the two hoses.
  11. Disconnect the electrical connector to the pump
  12. Lift the pump motor and pull it out from cabinet.
To put in new pump.
  1. Insert the two hoses on new pump.
  2. Set the clips.
  3. Put the pump motor in place inside the cabinet.
  4. Arrange hose and pump motor correctly and put screws back.
  5. Reconnect the wiring connector.
  6. Lift up the appliance.
  7. Put back spray arms and internal assembly.
Before putting on the front panel:
  1. Connect power and test for leaks.
  2. Disconnect power and fix any leak present (adjust hoses).
  3. If there is no leak put panel back.
  4. Set back the appliance and connect power.
Always observe strictly health and safety prescription. Disconnect power before performing any maintenance. Beware of panel's sharp edges, particularly when removing kick panel and accessing parts in the tight space under the bottom of the tub.
Here diagrams showing all parts:Exploded view.
Regards.
Ginko
Sep 07, 2011 | Dishwashers
My kennmore he2t frontload washer floods or doesnt drain the water. half of the water sits there and get absorb by the clothes. How do i fix this?
The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful.
Thanks for using FixYa!!
Nov 21, 2010 | Kenmore Front Load Washer
Titan spray gun issue
the fitting on the gun is bad or the wrong one. get a new one with the right threads for the gun end and the corrisponding fitting for the hose end. gun may be npt thread and hose might be jic thread.
chances are home depo has the correct fitting.
Oct 28, 2009 | Air Tools & Compressors
Water leaking
hi friend,
Step 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
  • Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  • Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  • Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  • Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  • Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part
  • hope this helps u
    thank u for using fixya
    please rate me.................
    regards
    sivaranjini
    Sep 12, 2009 | Kenmore Washing Machines
    My air conditioners is a everstar model mpa-08cr, and i need to instal the water hose on the side of unit.
    Hey there, just follow these simple steps then you'll be on your way
    To connect the continuous drain option. Remove
    the water tank from the cabinet. Inside the
    cabinet (water tank area) you will find a section of
    hose hanging beside the water tank, which is plugged
    at the end. Remove the plug
    from the end of the hose and install the drain hose connector
    (included with this unit) into the
    end of this hose section. Route the end of the
    hose (with drain connection) into the water tank,
    then through the hole provided in the face of the
    water tank. Attach a section of garden hose (to
    suit your continuous drain option requirements)
    to the drain hose connector. Place the open end
    of the hose directly over the drain area in your
    basement floor.
    Please make sure the drain hose
    section routed through water tank does not interfere
    with the correct positioning of the water tank inside
    the cabinet, or the will fail-safe switch mechanism will
    be activated, not allowing the unit to operate.
    Jun 19, 2009 | Danby DPAC8020 Air Conditioner
    Simpson enduro 701 overflow and dumping water on floor
    This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
    Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
    NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jun 06, 2009 | Washing Machines
    I have a ortho tree & shrub spray-ette hose end sprayer. The instructions say to add product and fill to gallon mark, then attach to hose and turn on water and spray. It isn't plugged the water comes...
    sound like the inside suction hose is loose or not fitting correctly. i had a similar problem and wrapped some duct tape around the tube then snugly fit it inside the cap. no outside air suction and it works fine. i've had mine going on 15 years and use it constantly.
    May 06, 2009 | Ortho Garden
    Refrigrator
    If you are lucky you can use a John Guest Push-Fit" connector to reconnect the two ends together..if you have enough hose to work with ..sometimes you can pull on the end that goes into the refrigerator cabinet to give you a little more hose... let me know what you do? krazytech
    Sep 10, 2007 | Whirlpool GD2SHGX Refrigerator
    Evolution Spas Ventura 90-jet, 6-Person Spas, Hot Tube, Hot Tubs,Patio Ideas,New Logo
    75 people viewed this question
    Top Evolution Pool & Spa Experts
    Jay Finke
    Jay Finke
    Bill Jordan
    David Spradling
    David Spradling
    Are you an Evolution Pool and Spa Expert? Answer questions, earn points and help others
