Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Motor runs but it does not grind
Brand new , motor runs but it does not grind
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
Just bought a brand new Husqvarna 224L Trimmer. Started it up and it runs fine. But the trimmer head will not turn. It just makes a grinding noise. The manual that came with the trimmer is useless. It says...
Hi, take it back to the dealer as the powered or gear box have not been fitted correctly. The noise you can hear is most likely the clutch drive grinding on the drive shaft. Hope this helps, regards Phil.
Jul 21, 2011 | Husqvarna 28cc Gas Line Trimmer
Starter problems
I had a simular problem with a buick motor in my 68 jeep pick-up.The distributer shaft bushings were worn to the point of irradical fireing,even back firing dureing start-up and shattered the houseing on the new starter.It could advance your timeing and cause your motor to run hot and become har to start.GOOD LUCK! Idaho Gym.
Aug 28, 2008 | 1988 Ford Bronco II
Starter problems
Starter Bendix solenoid. Change entire starter. If planing to keep car long time buy a lifetime warranty one.
Jun 24, 2008 | 1985 Ford Bronco II
Washing machine
THAT GRINDING SOUND is coming from the main motor , first you have to check a CAPACITOR located near the motor , disconnect it and try START AGAIN , IF it still giving you the grinding sound check if its coming from the motor , if so youre gonna need to replace it , cause the motor come from the factory SEALED ,making it imposible for repair,hope this helps AJ
May 06, 2008 | Kenmore 22422 Top Load Washer
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
27 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
