Question about Seal U.S. Mfg. Ps 201 Replacement Pump Shaft
Asembaley installation order
    Genius:
  • 1,198 Answers
Instructions usually come with the seal kit. The tricky part is getting the impeller off without damaging it. There is a flat on the other end, not easy to get at. Then it's just a matter of carefully removing the old seal and setting in the new one, cleaning the place where it goes.
Posted on Nov 29, 2013
Drivers installed out of order and computer will not boot up
What do you mean out of order, who told you there was an order ?
Even if you fresh installed windows, it doesn't matter which drivers you install, there is no order.
Installing chipset INF, Video driver, Sound driver, Sata driver, Sata controller, Lan driver, USB drivers, Wireless, MEI driver.
Most important drivers get pre-installed by windows using generic or signed by the hardware MFG.
So until you install the updated driver, it has the generic.
The most important thing is to reboot after each driver and not just install all of them and reboot.
Try safeboot, last known config, or a system restore.
Apr 12, 2013 | Computers & Internet
Spark plug wires installed wrong need to know how to install them right?
  1. 4 cylinder firing oder is 1-4-3-2
  2. 6 cylinder firing order is 1-6-5-4-3-2
  3. 8 cylinder firing order is 1-8-4-3-6-5-7-2
  4. firing order goes clock wise
Nov 11, 2010 | Chevrolet Blazer Cars & Trucks
Just wondering if you have a breakdown diagram for a 1992 dodge colt 1.5l distributer
I do not have a breakdown diagram for a distributor, but just the firing orders and description of ignition system for the Dodge Colt and related models (based on Chilton manuals) if that's what you're looking for: FIRING ORDERS Fig. 1: 1990 1.8L SOHC Engines Firing order: 1-3-4-2 Rotation: clockwise 84182009.gif
Fig. 2: 1.6L DOHC Engine Firing order: 1-3-4-2 Distributorless Ignition 84182010.gif
Fig. 3: 2.0L Engine Firing order: 1-3-4-2 Rotation: clockwise 84182011.gif
Fig. 4: 1.5L Engine Firing order: 1-3-4-2 Rotation: counterclockwise 84182012.gif
Fig. 5: 1993 1.8L Engine Firing order: 1-3-4-2 Rotation: counterclockwise 84182013.gif
Fig. 6: 2.4L Engine Firing order: 1-3-4-2 Rotation: clockwise 84182014.gif
To avoid confusion, replace spark plug wires one at a time. --- Distributor REMOVAL & INSTALLATION Although the distributor can be removed from the engine no matter which cylinder is about to fire, it is a good idea to have number one cylinder at TDC before distributor removal. 1.5L, 1.8L, 2.4L SOHC Engines
  1. Disconnect the negative battery cable.
  2. Disconnect and tag the spark plug wires from the distributor cap.
  3. Disconnect the distributor harness connector.
    Fig. 1: Ignition system for the 2.0L engine 84183001.gif
    Fig. 2: Ignition system for the 1.5L engine 84183002.gif
    Fig. 3: Ignition system for the 1992-93 1.8L engine 84183003.gif
    Fig. 4: Ignition system for the 2.4L engine 84183004.gif
  4. Loosen the distributor retaining bolt and remove the distributor from the engine. To install:
  5. Rotate the engine until No. 1 cylinder is at TDC on its compression stroke. NOTE: Be careful not to turn it to the No. 4 cylinder TDC on its compression stroke by mistake.
  6. Align the distributor housing and gear mating marks.
    Fig. 5: Ignition system for the 1990 1.8L engine 84183005.gif
    Fig. 6: Distributor installation for the 1990 1.8L engine 84183006.gif
    Fig. 7: Distributor installation for the 1992-93 1.8L engine 84183007.gif
  7. Install the distributor into the engine, while aligning the fine cut (groove or projection) on the distributor flange with the center of the distributor mounting stud.
  8. Install and tighten the distributor retaining bolt.
  9. Reconnect the distributor harness connector.
    Fig. 8: Distributor installation for the 2.4L engine 84183008.gif
    Fig. 9: Distributor installation for the 1.5L engine 84183009.gif
    Fig. 10: Distributor installation for the 2.0L engine 84183010.gif
  10. Install the distributor cap and spark plug wires.
  11. Reconnect the negative battery cable.
Oct 11, 2010 | 1992 Dodge Colt
Installed Dell Dimension audio and video drivers in worng order. Now, no sound amonng other things. How can I unistall and reinstall the drivers and start over. The chipset and network drivers were in the...
Try re-installing them in the correct order over the top first and see if that sorts it.
Normally though, it shouldn't matter in which order you install the sound and video drivers, they should still work.
if you are using windows xp you can go into control panel, system properties, device manager and delete the incorrect drivers from there.
Aug 27, 2010 | Dell Dimension 3000 PC Desktop
Sims 2 installation
You must install the expansion packs in a semi-fluid order. That is, there was an order they were released and for best results, you should install them in the same order.
http://compsimgames.about.com/od/expansionpacks/qt/sims2_exporder.htm
The above site is the order of the expansions. Keep in mind, it starts at the top and goes down (oldest at top, newest at bottom). You must use the latest most expansion pack's disc to play. That means, if the last expansion pack you have is "Seasons", you will need to use that disc to play the game.
Due to copyright laws, I'll be unable to assist you in how to play the game without the need of the discs but in essence, the above information will at least get the game installed with the expansions in the proper order. You and your friend may just be unable to play the game at the same time.
Jun 09, 2009 | EA - Electronic Arts The Sims 2: Open for...
Re-installing drivers on dimension 4550
You don't mentioned the model you ask for, but from my experiance, usually it has to be done in the following order:
1. Chipset/motherboard
2. IDE/SATA (if any)
3. VGA
4. Audio
- Wireless Lan
- Lan
- Modem
- TouchPad
- WebCam
- Special (Quick-launch) Buttons
- Utilities
- Software
of which firs 4 are important, other drivers can't realy cause problems if you mix their order of installation.
Regards.
Mar 27, 2009 | Computers & Internet
No videon
it sounds like an issue of driver installation order. If not installed in the correct order, the drivers may not function correctly. The correct order is:
Desktop System Software
Chipset Utility
Video Driver
Audio Driver
Modem Driver
Network Driver
My suggestion is to do a system restore to the 1st available restore point (The one created at boot after you reinstalled) then install the drivers in the correct order. (NOTE: Before you can play a DVD, you will have to install the DVD player too)
Jul 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I purchased norton 360 version 2.0 order no 1849616067 iwish to use it on my laptop since 3 month free useage expires in 2 days could you please instruct me how to do this as i believe i can use this...
Dear Sir/Madam,
Norton 360 2.0 may be installed on three computers at one time. If you have the product on a CD, you can install it on other two computers using the same CD and the same Product Key. Go to the section "I have a CD version".
If you have purchased the download version of Norton 360 2.0, you need to download and install Norton 360 2.0 on the other two computers, using the same purchase order details. Go to the section "I have a download version".
1. Go to the Symantec Store Order Status Web page on your second or third computer where you want to install Norton 360 2.0.
2. Type your order number and password to log on, and click Find your Order. You will see your order information.
If you do not know your order number and password, you can look up your order using your emailaddress and last 5 digits of your credit card.
On your Order Summary, click Start Download.
If you purchased your product more than 60 days ago, you can click Buy Now to buy the Extended Download Service and download the product again.
Double-click the file that you downloaded.
Read the License Agreement, type your Product Key if prompted, and then click I Agree.
If you do not accept the License Agreement, you cannot continue the installation.
In the Installation Options panel, review the options, and then click Next.
Follow the on-screen instructions.
1.I have a CD version
Insert the CD into the CD-ROM drive.
2. Click Install Norton 360.
3. Read the License Agreement, type your Product Key if prompted, and then click I Agree. If you do not accept the License Agreement, you cannot continue the installation.
4. In the Installation Options panel, review the options, and then click Next.
5. Follow the on-screen instructions.
Thanks
Good Luck
“Don’t Forget to rate the Solution”
Jun 06, 2008 | Computers & Internet
Seal U.S.  Mfg. Ps 201 Replacement Pump Shaft Logo
37 people viewed this question
Top Seal Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Seal Pool and Spa Expert? Answer questions, earn points and help others
