Question about Epson WorkForce 1100 Wide-Format Color Inkjet Printer C11ca58201
Epson WorkForce 1100 Inkjet Printer were is the waste ink pad or tank
Can reset paper & ink light
3 Suggested Answers
  • 169 Answers
SOURCE: wast ink counter epson stylus cx 9300f rest
Download the adjustment program (see below)
Extrak adjustment you have downloaded
Go to The extrakded folder then click tricks-collections.bat file
Now set the date setting in you PC to 11 April 2008,
Run adjustment program by click AdjProg.exe file the click accept
Click Particular adjustment mode then select destination and printer port then click OK
Select Waste ink pad counter from the below window and double-click to execute it
Click [Check] button to check current protection counter's value.
Then Click [Initialization] to reset the protection counter to the initial value. Thats all.
After finishing, you can change the date to normal.
Link Adjustment program for epson CX7300, CX8300 and CX9300F
Adjustment program for epson CX7300 : http://www.mediafire.com/?8wrkugah2mj
Adjustment program for epson CX8300 : http://www.mediafire.com/?0xfnrgarvuj
Adjustment program for epson CX9300F : http://www.mediafire.com/?o020wlaf6te
Posted on Jul 29, 2012
websnail
  • 419 Answers
SOURCE: epson workforce 1100 printer's ink pads are at the end of their service life
You need two things to resolve this issue...
1. To replace the waste pads or redirect the waste ink flow to an alternate collection vessel (eg: an external waste ink kit).
2. Reset the printers internal waste ink counter.
Both of these can be handled at an Epson service centre, usually at unrealistically high cost and often then don't bother replacing the pads unless you specify this at the time.
Alternatively you can find an external waste ink kit to deal with the waste ink such as the Printer Potty (plenty on the web so a search should be easy enough).
Instructions for fitting a waste kit are available here:
http://www.octoink.co.uk/kb/questions/123
Resetting the waste counter can be done using the T1100 adjProg which is available from various sources on the net if you look around.
Key thing to note with the waste tubes, especially if you've fitted external waste kits before, is that the waste tube runs in the opposite way to other Epson inkjet printers. The tube runs from the pump round the back and then towards the pads at the front.. See the guide above for a clearer indicator of what I mean.
Posted on Nov 30, 2012
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
My epson WF 840 has had counter reset, and waste ink pds changedbut, message reads, printers ink pads at end of life, switch off printer
Google epson waste ink pad resetter.this is a small program from china.you may be in luck and be able to reset the counter.download program run it, select printer from drop down menu.right click icon, reset waste ink pad.switch off printer restart.you may need to do this again.this program also resets cartridges before they become empty so you can get more out of them.
Nov 27, 2014 | Epson Workforce 840 Wireless Inkjet...
Epson workforce 1100 flashing lights
please help me to find epson office me 1100 resseter
Jun 13, 2012 | Epson Workforce 1100 InkJet Plotter...
Epson workforce 1100 printer's ink pads are at the end of their service life
please clean ink pads place and re install in pads and solve the problem
May 07, 2012 | Epson Printer
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Paper lights and ink lights flashing,/power light off, /mac os x tiger 10.4
Sound like the maintenance request (ie: waste ink pads are full).
This has been documented in detail so check the link below for more info' but the short version is this..
When the printer reaches a point in its internal logic that makes it think that the nappy pad is full or in danger of being full of waste ink it will indicate a "service required". At this point you can either take the printer to an Epson service center/tech and get it serviced for a considerable amount of money or you can reset the waste counter and fit an external waste tank/kit.
The latter approach is covered with these links below but there's plenty more on the subject if you need it so hope this lot helps.
Modifying the printer to use an external waste tank.
http://www.wasteink.co.uk/waste-ink-mods/epson-1400-mod/
Resetting the waste counter:
http://www.wasteink.co.uk/epson-ipr-reset/
Jun 10, 2009 | Epson Stylus 1400 InkJet Photo Printer
Flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Open Questions:
Epson WorkForce 1100 Wide-Format Color Inkjet Printer C11ca58201 Logo
126 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
