Question about Sportsart Exercise & Fitness
Led7 lit on sportsart 6320 treadmill and getting err1
I am getting err1 on my display as soon as I try to make the walk belt move. I have replaced the brushes, checked connections, called SportsArt, all to no avail. LED7 is lit, which apparently indicates that the current is too high and the driveboard is not supplying current to the motor to protect it. Is there a way to reset this LED? Does anyone have any other thoughts? The motor itself is functioning fine. Thanks!
4 Suggested Answers
SOURCE: my sportsart 6150 treadmill gives an error code 1
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
Posted on Feb 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: I just bought a sportsart 6320 treadmill second
Hi Les
Did not know you were out there! Unplug your unit take the motor shroud off on the motor their are black caps on each side these contain motor brushes pull them out 9 out of 10 times they will be less than 3/8" in length you'll need replace them. Call Sports Art @ 1-866-709-1750 they will sell you those brushes
Posted on Mar 12, 2010
maxtreadmill
  • 832 Answers
SOURCE: Sportsart 3200 Treadmill Belt motor problem
5v DC equals .5 mph every 10v equates to 1 mph try increasing the speed if the DC voltage increases that means the motor control is working properly, then go back to the drive motor and check the motor brushes even though you have used a DC power source. They sometimes will not seat correctly and cause no belt movement, use a commutator stone a clean up the commutator arm.
Posted on Jun 01, 2010
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
How long does it take for someone to help me, on this site.
How fast you get answers depends on many factors. I just picked up your question but have spent time finding and reading the manual. I am by no means a treadmill expert, but my first thought was treadmill belt tension was too loose to keep the movement sensor happy.
Moving the belt manually would be irrelevant as the electronics would not be monitoring to throw up the E1 Error..
The manual tells you to check all these things.
E1
Loss of Feedback Speed Sensor disconnected Check Speed Sensor
Connection
Speed Sensor Misaligned Check Sensor position
Faulty Speed Sensor Replace Speed Sensor
Loose Display Connection Check Display Cable
Connection
Faulty MCB (D2 LED on) Replace MCB
Faulty Drive Motor Replace Drive Motor
If BH Fitness are being no help, I would be asking them to take the machine away or get it fixed on-site.
So does the belt turn when you switch it on? Is the belt centrally aligned when it spins?
Page 35 shows belt adjustment and I would guess tension although not specifically mentioned.
http://www.bhfitnessusa.com/manuals/final/ts2.pdf
Jan 05, 2016 | Bh Fitness TS2 Folding Treadmill
Sportsart 1050l gives error 1
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Aug 01, 2014 | Sportsart Exercise & Fitness
What is E-1 error in Sportsart Tradmills
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
E01 sports treadmill
This link is to the service manual. You will find error code definitions and troubleshooting flowcharts.
Apr 12, 2014 | Sportsart Exercise & Fitness
Sportsart 1080 treadmill error 01
Mar 17, 2014 | Proform Power 1080
I have a Sportsart 1050l give's error 1?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
ERR1 Condition: Press speed key; walk belt doesn't move; ERR1 appears. 1. Drive Board a) Inspect drive board components for signs of damage, like bulging, burnt or cracked spots. b) Inspect connections to the drive board, including the ribbon cable (at the display and drive boards), drive motor, incline motor, etc. loose connections are a common cause of ERR1. c) Check the drive board lED Turn on the unit. The should be lit. The EMG indicator should light up and then extinguish after the unit powers up. A lingering EMG light indicates drive circuit trouble, but it can also light up if drive board connections to motors and other components aren't secure. d) Test whether the drive board is sending power to the motor. Put the muttimeter to the DC setting. Disconnect the motor M+M- wires from the drive board. Place probes on the drive board M+ M- terminals. Put the treadmill safety key in place; turn on the power; walk on the treadmill so that the ClK lED lights (this preempts the display from detecting no optic sensor signaling and immediately giving you an ERR1 message, thus allowing you to get a power reading); press the speed up key. The meter should show some voltage. If there's no voltage, inspect the ribbon cable and display board. If they appear OK, suspect the drive board. e) Test drive board components for a short. See Components in the Basic Electronics. 2. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 3. Display Board a) Press down on the display board ICs. If you have a working unit of the same kind, swap the display board onto this unit. Test. If all works well and no ERR message appears, replace the original display board. a) Reed Switch (Applies to models with magnetic safety keys only.) Put the safety key in place over the reed switch. Put the meter to the 200 Ohm setting. Place probes on both ends of the reed switch. Meter should show 0 Ohm. If the meter doesn't get a reading, replace the reed switch. 4. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn the brushes around and reinsert them. Rotate the flywheel. If the motor grinds or sticks, put brushes back in their original position. c) Check motor resistance: Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor wire M+ M- ends. Normal reading: 1 Ohm. Move the flywheel slightly and take another reading. Take a few readings, moving the flywheel slightly after each. Readings should be consistent. If the meter shows OL at any test point, replace the motor. 5. Transformer a) Put the meter to the AC setting. Place the meter probes on the transformer output wire connectors on the drive board. Turn on the unit. There should be output voltage. If not, replace the transformer. • 11XX/12XX brown-brown: 10.5VAC • 31 XXl32XXl61 XXl62XX white-white: 12.5 VAC • 6005 yellow-yellow: 11.0 VAC If ERR1 is not resolved, see ERR1 with walk belt movement. • • • • ERR1 Condition: Press speed key; walk belt moves; ERR1 appears. 1. Tachometer Wheel Make sure the tachometer wheel: a) Rotates in the middle of the optic sensor. b) Is clean and free of cobwebs and dust. c) Doesn't have broken or bent teeth. d) Is fastened securely on the motor bracket If the wheel has visible damage, replace it. 2. Optic Sensor Make sure that the optic sensor signal is getting to the drive board. a) With power on, turn the drive motor. The CLK indicator (an lED on the drive board) should light. This means that the optic sensor signal is reaching the drive board. If the ClK indicator doesn't light, replace the optic sensor. b) Push the treadmill belt while pushing speed up key. If ERR1 doesn't appear until you stop pushing the belt, and the display speed values increase, then the optic sensor is good. (On units without a ClK indicator, check optic sensor output voltage: (a) put probes on optic sensor output (b) turn the motor (c) if voltage doesn't vary, replace the optic sensor.) 3. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 4. Drive Board Check whether drive board components are burnt or cracked. Check component connections. A drive board power component short usually results in a huge burst of power, making the walk belt speed dangerously, before ERR1 appears. If the walk belt moves before ERR1 appears, but not very, very fast, suspect the optic sensor. 5. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check motor resistance. Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor cable M+ M- ends. Normal reading: 1-2 Ohm. If there's no reading (OL), replace the motor. c) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn brushes around and reinsert them; rotate the flywheel by hand. If it rotates worse than before, put brushes back in their original position. d) High amp draw can indicate a bad motor. Other factors would be a worn walk belt and deck. Run unit power through a current meter. Tum on the unit. Normal amp draw at 3 MPH with no load on the walk belt is 1/2 to 1 Amp. 6. Display Board ICs Make sure that IC contacts on the display board are good. Press firmly on the ICs. Make sure you have the latest CPU version. If ERR1 is not resolved, see ERR1 no walk belt movement.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Sep 15, 2013 | Exercise & Fitness
How to fit a new walk belt
proceed according and use common sense;God bless you
Jul 25, 2012 | Sportsart 6300 Treadmill
Sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Mar 13, 2010 | Sportsart 6300 Treadmill
I just bought a sportsart 6320 treadmill second hand and on the screen now it says (err1) and will not start everything else comes on but soon as you push the run button it goes into this err1 mode, can...
Hi Les
Dec 17, 2009 | Exercise & Fitness
Exercise & Fitness Logo
26 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven's...
Steven's...
Tom Chichester
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
