Question about Baxter BXA2G Stainless Steel Gas Single Oven
Hearing a buzzing every second
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
Duke 59-E3XX Contactors buzzing when starting?
Contactors are getting weak and need to be replaced.............the buzzing is the magnetic coil making noise. Anytime I hear a contactor buzzing on a furnace, ac, or refrigeration rack I replace them immediately. Otherwise what happens is eventually it will get stuck closed (on position) and cause a issue later.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Duke 59-E3X Electric Single Oven
Mmv5207bas will not heat
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise.
Here is the part to order.
Jun 22, 2013 | Ovens
My daughter turned the timer but when it got to zero and it buzzed....it never stopped buzzing. It is still buzzing 10 hrs now! What can I do?
unplug your oven. sounds like you need a new timer. the relay is not releasing . cause the timer wont let it
Jun 19, 2011 | Kenmore Ovens
My lg microwave oven will not heat- fairly new
Do you have a display? If not, check power to the oven. If that is Ok, check the fuse (inside the control section). Or does it program, but not heat? Then the first things to check are the door switches. Do you hear a buzzing sound? Is it normal or loud? Loud means either a shorted diode, capacitor, transformer or magnetron. I could run you through this step by step, but I am new with FixYa and do not know how to do this and I do want to do it the proper way.
May 08, 2011 | Ovens
I have a 16 year old GE XL44 which has a manual turn clock that keeps buzzing. My husband stopped it, but it is going off again. The manuals I am finding on-line have electric clocks which we don't have....
Greetings,
Remove the power from the stove to prevent shock..remove rear access panal and locate clock....there will be a small motor attached to the clock..cut the wire going to the clock motor and tape....there are other ways, but this is easiest to explain..the clock will not be working after this...or, you can have your clock rebuilt or replaced with a current digital clock
Bruce Denton
Jan 04, 2011 | GE Ovens
I own a Frigidaire Gallery refrigerator model # frs24xgcw ,the freezer sidehas stopped cooling and there is an occasional buzzing noise. Refrigerator side is working.The refrigerator is approximately 11...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
I just bought a new oster OGF41101 microwave oven. There's a loud buzzing sound when I hit Start button, this sound is off after couples of seconds. Is it normal operation for this version?
did you take the plastic wrap off of the spinner inside the microwave? If not it is wrap around it and it makes that sound when the plate spins.
Jan 09, 2010 | Ovens
F 11 showed up buzzing noise maybe timer?
HI. this is a board failure code. try to revive it by shutting the power down for 30 seconds. if this dose not produce positive results, you will need to replace the damaged oven control board.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Baxter BXA2G Stainless Steel Gas Single Oven Logo
41 people viewed this question
Top Baxter Ovens Experts
Lawrence Oravetz
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
