Question about HEWLETT-PACKARD Mini 1030NR (FW376UA) PC Notebook
HP FW376UA Hard drive size
    Problem Solver:
  • 7 Answers
If you want to know about the size of hard drive just right click on My Computer > Manage > Disk Management .
After that you can see all the drives, all unallocated space and stuff.
Just add them and it will tell you about size!
Posted on Dec 04, 2013
Maximum hard disk size for hp a1610n
Based on The Spec's of your System you have a 250gb Hard Drive however the Maximum size will be less then that due to formatting the drive so you can expect that to be like 10% less then 250gb (just a guess) plus a lot of computers come with a restore partition which is usually around 12gb assuming you leave it factory stock.... Your computer by default will set your Hard Drive to the Maximum size... now as far as how big you can install the sky is the Limit your computer is new enough it should except any size Hard Drive available at the store.
Oct 14, 2013 | HP Pavilion Computers & Internet
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
I have an hp nx9010 and the hard drive appears to have failed if I am buying a new hard drive what type do I need? IDE or SATA and should I look for a certain rotation speed? The current hard drive is a...
This model laptop is installed with an IDE 40Gb hard drive.
You can use a faster hard drive but the BIOS limits the maximum size hard drive you can install.
Check the specification of this laptop for the maximum size hard drive you can install.
May 22, 2011 | HP Compaq Business Notebook NX9010
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
I WANT TO ADD A SECOND HARD DRIVE WHAT WOULD BE THE PART NUMBER FOR THE CADDY.. AND ALSO UP TO WHAT SIZE HARD DRIVE CAN I ADD
The only practical way to add a second hard drive to the dv9720us is to use an external USB unit. There is no provision for a second internal hard drive (standard for laptops). The "expansion port" is simply another wire connection to the motherboard's data bus, and requires a proprietary cable from HP. Using a USB external drive is a standard approach and does not require any special drivers, etc.
There are a number of good external hard drives w/USB connection available from Costco, WalMart, KMart, and other retailers. HP prefers Western Digital (as do I, from years of repair experience...they last longer), but there are a number of decent brands. You can use any size you want. 1TB drives are not uncommon today. Prices generally range from a little under $100 to around $200 for large capacity drives.
Hope that's helpful.
Jan 01, 2011 | HP Pavilion dv9720us Notebook
What is maximum size for hard drive on HP pavilion dv6105us ?
There is no maximum size hard drive for the DV series laptop, especially if you are running Vista or Windows 7. If you are running XP, make sure that the operating system has service pack 3 in it and you can run any capacity drive you wish.
Jun 27, 2010 | HP Pavilion dv6105us Notebook
I inherited a zd8000 and need to buy a hard drive.
This one http://www.newegg.com/Product/Product.aspx?Item=N82E16822136130   is more than enough for your needs.
Mar 11, 2010 | HP Pavilion zd8000 Notebook
NEED HELP...HP G70-467CL NOTEBOOK PC BLUE SCREEN COMES UP AND STATES THAT WINDOWS HAS BEEN SHUT DOWN TO PREVENT DMG.
if this is an ongoing problem with the blue screen then the hard drive is surely lost there is a very slim chance of getting anything of the hard drive you can try to if you believe you can put my suggestion is to just replace the hard drive and if under warranty go to www.hp.com/support and see what is need to have the hard drive replaced if not under warranty then finding a replacement will depend on brand and size if you would like too up the size or just keep the same size. Replacing it shouldn't be a problem the only thing that is technical is the re installation of the operating system and drivers of the laptop
Feb 13, 2010 | HP Pavilion dv9000z Notebook
HEWLETT-PACKARD Mini 1030NR (FW376UA) PC Notebook Logo
37 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
