Question about Pool & Spa
I have a new H400 Hayward poole heater. There is white smoke coming off the top. I thought it would stop after a few minutes however it has not stopped after 45 minutes. The heat transfer is good and it seems to work well...other than the smoke. What can I do to resolve
  • 1,631 Answers
Are you sure there is nothing on top of the burners?
It is normal for the heater to burn some smoke because of residual oil on the exchangers, but you would think 45 minutes is plenty of time to burn it off? Try for a little while longer? Maybe it is not smoke? could be steam? Possible of condensation or small leak? What is your water flow like? Is pressure too high, is flow to high or to low? These may need to be checked by a service tech. Because this is a real problem when you get "Rain inside your heater" Possible improper installation?
Posted on Jan 29, 2014
  • 10 Answers
SOURCE: I'm trying to start-up a Hayward H400 natural gas
if means ignition failure check that gas is on, check for fauilty igniter wiring or connections, inspect gas valve wiring measure voltage across gas valve during trial to ignition if 24 volt replace gas valve if no 24 volt replace control module
Posted on May 19, 2009
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
john224
  • 1378 Answers
SOURCE: black soot like smoke coming out of top of pool heater,
Your flames should be blue; orange means a poor combustion mixture. Pull the copper jets out of the manifold one at a time and inspect the inside for spider nests. They are screwed into the black tube that exits your gas valve, bends down and then along the front of the burner tubes. You will likely find most of the jets blocked. If they are not or you still have a problem after cleaning them out, you'll need a tech to measure the gas pressure in and out of the gas valve.
Posted on Jun 13, 2009
  • 139 Answers
SOURCE: Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Posted on Jun 21, 2009
thepool
  • 78 Answers
SOURCE: Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Posted on Apr 23, 2010
Had a power outage yesterday now heater won't ignite. No error codes.
bo = 'Bypassed Operation'
heater is now controlled via your automation system.
Create a heat call, turn solar off if active.
Heaters should be set to auto on.
Mar 07, 2015 | Hayward Pool Products Hayward Universal...
Replace igniter on h400
Open the main door, locate the 2 white fabric coated wires, they go down towards the base of the heater. This is your igniter, usually a 5/16 nut driver will be the tool you need to remove it.
Jul 04, 2014 | Hayward H-series Electronic Gas Pool...
Hayward pool heater smoke
Is it smoke? Could it be steam?
If so, condensation "Rain in the inside of your new heater". This is a real problem & needs to be checked out by a Certified Heater Technical service man. Preferrably, not the one who installed.
Nov 22, 2013 | Pool & Spa
Hayward electonic pool heater Numeric display not working?
if voltage ok coming in and voltage coming from transformer ok then bad display
Sep 14, 2013 | Hayward H-series Electronic Gas Pool...
Hayward H-Series Not heating water
if all burners are working correctly then put a bypass on heater plumbing open it half way to slow down water flow that will give you a higher heat rise
May 05, 2013 | Hayward H-series Electronic Gas Pool...
I can not turn off ob on the screen of my Hayward pool heater
I looked up the owners manual for the Hayward H400 heater and it did not list the "ob" indication. For this reason I would call the and they likely can help you out.
Please let me know how this turns out. Thank you.
Aug 30, 2011 | Hayward H-series Electronic Gas Pool...
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
230 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
