Problem for Maytag Washing Machines
Generic problem for all Maytag Washing Machines
Leaking, but no service person
Leaking, but no service person seems to be able to determine from where the leak is coming. It is a Maytag. Purchased in 1991
Solution #1
posted on May 07, 2009
Rank: Guru
Rating: 86%, 17 votes
It leaks
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
- Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
- The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
- Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
- Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
- Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
- Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
- Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
I am looking for a new washer. What is the best one to buy that will last a lifetime. I have had a...
(More)
I am looking for a new washer. What is the best one to buy that will last a lifetime. I have had a neptune that failed and now a cabrio that has failed. these appliances are expensive and I have to pay for my water so I would like something that helps conserve and do a large load of clothes. We are a family of eight and definitely need a good appliance here.
What is the best portable washer to buy?
The Haier model seems cheap, and the kenmore which I was...
(More)
The Haier model seems cheap, and the kenmore which I was leaning towards owners say it doesn't fill up right.
I have ordered a new lid switch for my washer. Whats the quickest way to install it? Do you have a...
(More)
I have ordered a new lid switch for my washer. Whats the quickest way to install it? Do you have a video or written instructions on this. Just don't want to mess anything up.
the indicator light on the left for control lock is lit up, and I cannot start a load of clothes
I have a 10 year old (?) Zanussi IZ16 washing machine that has been working fine for all of its...
(More)
I have a 10 year old (?) Zanussi IZ16 washing machine that has been working fine for all of its life. I noticed a while ago that the jwt into the drum isn't working as it used to & it doesn't fill properly with water during a normal cycle. I've tested the water pressure comming into the machine (3.5 bar) and I think it is adequate. I also checked the inlet filter and this was clear. Any ideas on what is stopping the water from entering the machine?
