Question about Toshiba Satellite L505-ES5042 Notebook
Microphone feed back, i cant get my microphone to turn off, i set it up so my wife wouldnt have to learn to type using speak commands
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
You can go into the properties of the microphone and disable or fine tune to eliminate the feedback. If all else fails reinstall the driver.
Good first step.
See below: Windows 7 and eirlier
The information below is designed to help solve your microphone not working properly. This does not cover problems related to specific programs or third-party microphone hardware and software.
If your laptop microphone is not working properly, ensure it is not disabled:
  1. Open the Start Menu and type "Sound" in the search field.
  2. Select "Sound" from the results.
  3. Select the RECORDING tab and select the desired microphone. Default microphone is Realtek High Definition Audio.
  4. Click "Properties" to view and modify settings.
Reloading the sound driver may resolve this issue.
  1. Open the Start Menu and type "Device Manager" in the search field. Select "Device Manager" from the results.
  2. Locate and select "Sound, Video and Game Controllers."
  3. Identify the sound devices.
  4. Right-click on each one and select "Uninstall".
  5. Reboot the computer.
  6. Your drivers will automatically install. Third-party drivers may need to be reinstalled manually.
Posted on Nov 23, 2013
I can hear them on video chat but they cant hear me
make sure have installed the drivers for microphone http://www.driverscape.com/manufacturers/acer/laptops-desktops/aspire-5315/619
Jun 03, 2016 | Acer Aspire 5315 Notebook
Cp200 squeel
This is called feedback. The audio output from the other radio is feeding back through your microphone. Turn the volume down on the radio at a comfortable listening level, and do not transmit when in close proximity. If they can hear you speak, you do not need to transmit.
Jun 07, 2014 | Motorola Radio Communications
Apple MacBook Air Notebook
okay going to have a bash at solving this but it's a little hard based on your description. I'm guessing this has Mavricks operating system installed.
  1. Choose Apple menu > System Preferences, click Dictation & Speech, then click Text to Speech.
  2. Select the "Speak selected text when the key is pressed" checkbox. By default, speaking is enabled when you press Option-Esc. To choose a different key, click Change Key, press one or more modifier keys (Command, Shift, Option, or Control) together with another key, then click OK.
  3. To have your Mac start speaking, press the specified key. To stop the speaking, press the key again. If text is selected when you press the key, the selected text is spoken. Otherwise, available text items in the current window are spoken; for example, if Mail is the current window, an email message is read. If no text items are available, you hear a beep.
    So based on what you have described you have already found this option and set the change key to "command" + "e"
    Try rebooting then going to the text to speech option and attempt to set the key combination you want it to be. If this fails to change then try resetting the P-ram which should set it back to the default.
OS Mavericks Reset your computers PRAM
Mar 05, 2014 | Apple MacBook Air Mac Notebook
Cant hear other person on skype
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment
Dec 28, 2011 | Computers & Internet
I have a Dynex DX-28 headset. My headset from hearing works, but my microphone does not. I can hear people, but they cannot hear me. The bar for speaking will go up, but mostly only one bar will...
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
Apr 09, 2011 | Computers & Internet
Ive registerd and signed in but cant use skype
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make the right adjustments
hope this helps
Oct 25, 2010 | Computers & Internet
We cant figure out how to get the microphone to work on the band hero for the wii...???
Instructions
  1. Step 1 Plug the adapter into the USB outlet at the top of the Wii. Face the sensor toward where you will play. Boot up the Wii.
  2. Step 2 Press the button on the front of the microphone to sync it up with the Wii; a blue light will confirm that the sync was successful. Do this before or after you boot up the Wii, but before you select the video game you want to play.
  3. Step 3 Turn on the Wii and insert a microphone-usable game.
  4. Step 4 Speak. Use the microphone to choose commands (Wii Speak) or talk to friends over the Wi-Fi network (Animal Crossing). Stay in the range of the adapter, which is 3' to 9'.
Ps dont forget to rate me here in fixya,
Thanks guys
Feb 12, 2010 | Nintendo Rock Band for Wii
I cant get the microphone working
Try installing Drivers off the internet for it
Jun 24, 2009 | MPC Computers TransPort T3000 Notebook
Audio feedis crossing with my speaker feed with and without the microphone plugged in.
Your mic still picks up sound when it's unplugged ?
As far as the other prob goes that sounds like howl round ( feedback ), mute the mic when not talking through it or get a mic with a cardioid polar response pattern ( just ask for a cardioid mic, can get a hypercardioid or supercardioid too but a cardioid would be best for your application, point the mic right at your speaking position with the back of the mic pointing at the speakers wich ideally should be behind the mic, this will help cancel out their sound, puting a limiter on the mic and setting it where it only starts picking up sound when you talk directly into it will help too, but the sure fire way to solve the prob is to mute the mic when not speaking into it. What you definitely don't want is an omnidirectional mic, for what you are using a mic for.
Jun 10, 2008 | Logitech Labtech Verse 524 Microphone
How to hear my voice through my usb microphone?
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
Apr 24, 2008 | Logitech USB Desktop Consumer Microphone
Toshiba Satellite L505-ES5042 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
