Question about Dishwashers
Reset code kitchenaid kuds50fvss3
Clean light blinks 7 times then stops continuously and will not start. I know it needs reset, but i do not know the button sequence
the dr
  • 447 Answers
SOURCE: whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Posted on Dec 23, 2007
SOURCE: dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Posted on Dec 07, 2008
  • 25 Answers
SOURCE: Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Posted on Jan 23, 2009
  • 25 Answers
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
  • 188 Answers
SOURCE: clean light blinks 7 times continuously
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on May 04, 2009
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
How to reset control board on kitchenaid dishwasher
Check to see if there is a manual behind the bottom panel. It should tell you what that error code is. It may be the heater is not working or some other issue. You will have to repair the problem before this will stop.
Oct 02, 2014 | KitchenAid Dishwashers
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light blinks 7 times, pauses, then blinks 7 etc.?
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 25, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
Clean light blinks 7 times and will not start it is a STATUS KITCHENAID
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 10, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
