Question about NEC Lands Phones
Nitsuko phone system 124i/384i - My phone doesn't ring when everyone elses phone in he office rings for external calls. I want to be able to help answer the phone. How do I enable my phone to ring lik
The phones in our office were set up over 13 years ago. I want my phone to ring with external callers so that I can help out the front desk. There must be some type of setting that I can turn on and off in order to allow external calls to ring though to my phone without having to select a particular line first.
ginko
  • 19396 Answers
SOURCE: Extending a call to an external telephone number
You need to divert the calls.
Check this user guide
Posted on Jul 22, 2008
SOURCE: muted ring tones
pl mention ur model no & make of the system
Posted on Feb 08, 2009
SOURCE: since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Posted on Jun 15, 2009
cnavarro
  • 2460 Answers
SOURCE: I need to set the
Partner ACS systems come with Centralized programming instructions. Most of them starting with Feature 00 Left Intercom twice and Right Intercom. When you dial an extension, the lights will be solid or blink according to how it's programmed and you press each button to turn on or off or delay ringing.
Your system administrator should have a book.
Carl
Posted on Sep 28, 2010
SOURCE: We have a 92573 NEC
http://phone.manualsonline.com/manuals/mfg/nec_display_solutions/92573_1line.html
Hi please find above a link for your user manual. This is about the best I can do.
Try removing the phone from wall & telephone jack, wait say 5 mins, now reconnect it all back up.
Then using the manual and working from step ONE.. work through the setup steps FROM THE BEGINNING, I know it's a pain but...just do it..lol.. and I am sure you will prevail, usually it is a simple wrong or miss-step that can muck things up... so just carefully and slowly work through the settings and hopefully you will prevail
However IF after you have done so, and you are sure that you are right in what you have done, then you may indeed have a faulty instrument, of course the ONLY way to eliminate this is by substitution, with a "Known good" unit.and try that one in it's place.
But often before I consign things to the "bin" I will often get an offsider to do exactly what i have done, IE: Re-setup the device, sometimes, they will interpret things differently and may see a misstep or mistake, or step that has been made, that one may have missed, remember the object is to get it all going again, and it doesn't matter how it gets fixed.
Posted on Mar 17, 2011
Why my nitsuko tx serise nxe2464m tx extension phones are not riging
Ringing is assigned in system programming, either a tech or your office in house tech will need to make the change.
Jul 03, 2014 | NEC Dterm DTP 16D-1 Corded Phone
User manual for 124i/384i telephones
Check in NEC Site or this link NEC 28i / 124i / 384i Telephone System User Guide
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 14, 2011 | Lands Phones
MY EXTENSION DOESN'T RING FOR EXTERNAL CALLS ON THE KX-T7433 SYSTEM WE HAVE INSTALLED. HOW CAN I GET IT TO RING FOR INCOMING EXTERNAL CALLS?
JUST AS YOU'RE TOO LAZY TO USE THE SHIFT KEY AND LOSE THE CAPS LOCK KEY, I'M TOO LAZY TO LOOK UP THELINK TO A MANUAL. HOWEVER, I CAN TELL YOU THAT YOU COULD GO TO THE PROGRAMMING MANUAL FOR A PANASONIC KX-TD 816/1232 AND LOOK AT DIL 1:N PROGRAM 603 AND 604. IT'S WHERE YOU SET THE EXTENSIONS THAT RING WHEN A CALL COMES IN.
Carl
Jun 23, 2011 | Panasonic KX-T7433B Corded Phone
Hi I have a Panasonic KX-T7667 Telephone and it rings for intercom calls, but for external line calls it won't ring, I just get the flashing lights for the phone line. I have tried the volume...
Solid lights mean it's not programmed in the ICD group. Depending on the issue of your system cabinet, ICD ring group pilot numbers begin with 600 or 601 and grow to as many as you need. Each phone that rings has to be a member of the group and you can program it to not ring, ring immediately, or a delay of up to 6 rings. In my office system ICD group members are assigned in system program 620.and the ringing is programmed in 621. It's not entirely friendly to change it by hand as the tables are assigned by group and position, but it can be done.
It's an installer function and requires the system password or permission to change it.
Carl
Jun 19, 2011 | Lands Phones
I need to set the ringers to only ring at the two receptionist desks and not everyone else's offices. Please help! We have Avaya Partner 18D phones.
Carl
Sep 28, 2010 | Avaya Corded Phone avaparp18d
Ring tone for internal and external calls
this is a change your system administrator will need to handle, (or your phone tech). There is an option in the under "system options" called internal ring cadence for external callers; this is where you can have the system do a double ring for External and a single ring for internal or vice versa.
Jun 25, 2009 | Mitel 5212 IP Phone
Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
134 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
