It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
