Question about LG 55 55LW5600 3D LCD TV
Switching itself off,turn it on again ,it makes a clicking noise and goes off ,no picture
Pluged it out and plug it back in no result
5 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: LG Flat Screen Problem
since when have you experienced the problem? does the tv still turn on or not...?
Posted on Aug 08, 2008
dsacco86
  • 1077 Answers
SOURCE: 42 LG plasma no picture but sound. found internal
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
  • 8457 Answers
SOURCE: Whenever i go turn the tv on its starts making a clicking noise.
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Posted on Mar 17, 2010
freelance-au
  • 131 Answers
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
Posted on Apr 05, 2010
Tv won't turn on
I think its a defective convergence chip/circuit and need a tech to replace it. It could cost about $300 or so.
Nov 04, 2007 | JVC AV-56P575 56" Rear Projection...
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
Tv keeps switching on and off and will not stop
unplug tv for 2 minutes and plug it back in. problem should go away. if not, call toshiba.
Jul 22, 2009 | Toshiba 27AF41 27" TV
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Printer turns off and will not come back on after you push cancel
just unplug your power cord and push it back.then switch the printer on.please post your result
Apr 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cant get the tv to power up
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Oct 15, 2006 | Mitsubishi VS-55601 55" Rear Projection...
LG 55 55LW5600 3D LCD TV Logo
27 people viewed this question
Computer Repairing
Computer Repairing
