How do i connect my rca thome theater receiver to my toshiba television
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
1 yellow cable from home theatre Video out to TV video input and push the TV/ video or input button on the TV remote, next take red/white cables and plug one end into your satellite or cable box to audio output and connect those to the audio input on the home theatre. them push the Fucntion button to AUX, should be working after that.
Posted on Nov 29, 2013
Can I connect exterior speakers to my DP32670 television? Thanks Tom Moreland
Hello:
In order to connect external speakers to your DP32670 television, which has only RCA audio and digital audio outputs, you will have to either:
  • Use speakers that were designed to accept an RCA audio input
  • Use a separate home theater receiver connected via either RCA audio or Digital audio
Mar 06, 2011 | Televison & Video
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
How do you connect the speakers on to your flat tv. I read it on the manual that u have to use HDMI, but i did. It still won't work.
This model has speakers. If you are trying to connect external speakers i.e. a home theater system, receiver or a sound bar you have a couple options.
This television only has hdmi inputs so you cannot connect the external speakers with hdmi cables. The television would have to have and hdmi output.
Now in order to use hdmi you would have to connect all your devices to the home theater and then go hdmi out from the home theater to one of the two hdmi inputs on this television. Then you would leave the television on that hdmi input at all times and switch devices with the home theater remote.
All the devices would be connected from their respective outputs to a respective input on the home theater.
Another option is to connect a fiber optic cable from the television to the home theater.
Another option would allow for stereo sound but not the higher quality surround sound. You can connect from your televisions red and white RCA outputs to the RCA input on the home theater.
Dec 30, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
How to connect toshiba laptop to lg home theater stereo
Good day. You will need tyo get yourself a "sterio to RCA" cable. You will then plug the sterio plug into your laptop, and the RCA cables into the back of your receiver, lets say,AUX. Then set your receiver to the aux input and play your music through your receiver. Hope this helps
Aug 17, 2010 | Audio Players & Recorders
I have a 37 WLT 68 TV, is it possible to connect
Strictly speaking, no. Your TV has both a line-level audio output, via RCA cables, and a SPDIF (digital audio output) connector (and a headphone jack). Any of these will output a low-level signal into an stereo amplifier or home theater AV receiver. The speakers would be attached to that separate amplifier unit.
Oct 16, 2009 | Televison & Video
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ...
    forum.ecoustics.com/bbs/messages/3/9749.html - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ...
    www.retrevo.com/s/RCA-RT2360-Home-Theater-Systems-review-manual/id/402ag601/t/1-2/ - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ...
    www.shopping.com/xPF-RCA-RCA-RS2642-NEO-5-BOOKSHELF-SYSTEM-22342661 - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
Connecting a Protron PLTV 3250 to a home theater system
Standard RCA cables are fine to connect both units. If home theater and tv has Component Video (Green-Red-Blue) connections, you can get better video result.
Sep 11, 2008 | Protron PLTV-32 Television
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
How do I connect the receiver and television together
Try to connect AUDIO OUT from your TV to AUDIO IN to your receiver.
Oct 05, 2007 | RCA RT2600 System
Computers & Internet Logo
David Payne
David Payne
