Question about Refrigerators
How do i reset my ge txr26kp side by side refridgerator
Its not getting cold and the freezer is not freezing but the compressors is humming and it has vibration when I touch it. Its cold to the touch on the outside
    Sergeant:
  • 479 Answers
Generally a compressor is either warm or hot when running if cold it may not be running
Posted on Nov 22, 2013
docjohn174
  • 943 Answers
SOURCE: GE Profile PSS26NG Not cold
hi thanks for the question the problem you are having is with the defrost cycle . check the defrost timer and the defrost termination switch. and also clean all coils at the back, and clean drain tube ,from freezer to drain tray at the back. thanks the appliance doc. rate me please
Posted on Oct 01, 2008
SOURCE: I have a GSS22KGMC WW
i have a ge side by side the refridgfrator side doesnt get cold enough its turned all the way up to 9. could the temp, control have gone bad? thank you very much Larry
Posted on Jan 29, 2009
  • 531 Answers
SOURCE: GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Posted on Apr 07, 2009
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
  • 207 Answers
SOURCE: GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Posted on Feb 24, 2010
Won't freeze on freezer side ( defrosting) and won't get cold on refridgerator side
If you have confirmed that the unit is defrosting and the freezer isn't getting cold. Make sure underneath the refrigerator is completely clean and the fan is running underneath the refrigerator next to the coils. If this all checks out then you have a bad compressor or lost of refrigerant due to a leak in the system. One last thing: Is the cooling fan running in the freezer?
Oct 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Sep 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
