Question about Indesit 24 in. D63 Free-standing Dishwasher
My dishwasher when switched on keeps throwing the trip switch
Hi my dishwasher keeps throwing my trip switch my friend gave me advise and told me i maybe had to many appliencies on at the same time so i switched all off and tried just the dishwasher its still tripping the switch . please help as i have 4 young children and cant afford the repair bills
  • lbrinkman9 Nov 06, 2007
    like the previous post, bosch dishwasher throws the trip switch, I too have unplugged everything that might influence power surge-should I call electrician or plumber ???
I had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Posted on May 22, 2008
  • Sammy Apr 22, 2012
    Hi Sir, I have the same problem. and I have just read your advice on what to do.....guess what, it worked, I an so please. many thanks. great job. BIG THANKS to you. S at 07828147733.
Must be connected wrong.
Posted on Oct 19, 2007
2 Suggested Answers
SOURCE: my dishwasher when switched on keeps throwing the trip switch
have same problem with a dx6451 suspect either element or circulation pump any help out there
Posted on Apr 16, 2008
My dishwasher keeps tripping the eletrics when I switch it on !!HELP
Something in the dishwasher shorted out. Likely there is a leak somewhere. This assumes this developed recently.
It is possible the relay that controls the heating element is fused closed keeping power to the element continualy.
If it was a new install, the dircuit branch may be inadequate.
Dec 22, 2011 | Dishwashers
Power is connected but dishwasher will not start
Make sure (with and electric field tester/2-prong tester/DMM/VOM) that there's 120VAC to your
dishwasher. You can also check the circuit breaker - it may be OFF or TRIPPED.
Its easy to see when a breaker is OFF, but harder to see a TRIPPED breaker - the toggle
stops halfway between ON and OFF when a breaker trips, and its easy to miss in the dim
light of a typical garage or basement (this electrician knows from experience). To reset
a TRIPPED breaker, you must throw the toggle
switch to OFF, then reset it by throwing the toggle to ON.
If your residence has a fuse panel, check you fuse and consider buying a reset-able screw-in
replacement from your local electrical supply.
Feb 20, 2011 | KitchenAid Dishwashers
Causing electric trip to go off as soon as the dishwasher is switched on
Heating element at bottom of dishwasher cause of "throwing" trip, told this by manager of local electric store where machine was purchased.
Oct 11, 2009 | Creda Dishwashers
No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 13, 2009 | Maytag MDB7100AWB Dishwasher
Hi had trouble with water tap feeding dishwasher , was leaking
it trips the safety switch because the machine is unsafe
call an electrician to do an insulation check , wiring and component check
Nov 18, 2017 | Siemens 24 in. SE25A091 Hi-Line...
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Trip switch
is the dishwasher on its own circut breaker if so whats the size
Mar 17, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Try plugging into another socket preferably one that uses a different circuit. It could be a fault in the socket.
Feb 18, 2008 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwasher keeps throwing circuit breaker halfway thru cylce
Most likely cause is a minor leak shorting acroos the wires, check in base for water stains. Regards Advisor
Aug 31, 2007 | Maytag 24 in. MD5600 Jetclean II Built-in...
Indesit 24 in. D63 Free-standing Dishwasher Logo
1,502 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
