Question about Korg DT-10 Digital Tuner
I would like to calibrate my korg dt-10 to 432 htz,is that possible?
2 Suggested Answers
  • 5603 Answers
SOURCE: HOW TO CALIBRATE KORG DT-10 TUNER TO 440 TUNING
From the user manual:
While the setting is shown in the display, press the CALIB key to
set the calibration.
Each time you press the key you will cycle through the following
settings.
0: 440 Hz 2: 442 Hz 4: 444 Hz 8: 438 Hz
1: 441 Hz 3: 443 Hz 5: 445 Hz 9: 439 Hz
When you have made the desired setting, wait approximately two
seconds without pressing the key.
The indication in the note display will blink three times, and the
calibration setting will be completed. You will then return to tuning
mode.
Just do it and stop on the 440 one.
Posted on May 19, 2011
My Korg DT-10 Tuner is broken. I think it is the power supply. Do you think it is cheaper to repair it or should I just get a new one?
if your pretty sure its a crack in the circuit board from dropping or rough treatment then yes it can be repaired in less than an hour-contact a guitar repair center to see who does there electronics repairs they might take that on if asked , but if it just started to do this with out a known cause its most likely a component failure and that will take some time and knowledge to find cause and repair , on this unit that might not be feasible to do
Feb 29, 2016 | Korg DT-10 Digital Tuner
How I can fix key in korg pa800 did not work
Your best solution would be to take it to a repairman. There are too many possibilities as to the cause of the problem to guess at them online.
Jan 20, 2016 | Korg Music
What could be the problem, my Korg X5 will not power up ?
Two possibilities: power supply or internal fuse (and internal components ).
See if power supply works on another equipment or check it with a VOM.
Dec 03, 2014 | Korg Music
I have a Korg KP3 with a faulty touch screen. How can I get this fixed?
Take it appart rub it with pure alcohol an put the touchpad together again
Nov 23, 2014 | Dynamic Korg Kp3 Kaoss Pad Dynamic Dj...
Korg ax3000 g display not working
It is likely something internal. The LCD is backlit so there is a chance it may be something on the order of a bad connection at the power supply input. Possibly a broken wire- as long as unit was not dropped, using a multi meter to check power is a pretty straight forward way to proceed.
If it got wet, there is possibly a burned out pico fuse, or corrosion on a connector or contact area for the rubber conductors for the display.
If unit was dropped- You may want to contact Korg to see if the display board is available. It likely is not. Which means it is a time and or money investment.
Feb 12, 2012 | Korg Music
HI Fixya, My Korg DT-10 is broken, when plugin a cable, the light won't get on. I have some experience with opening a pedal look at the circuitboard to the problem, but this i can't fix it....
Just having "volts" does not guarantee they are the right voltage. Check that the adapter you are using is the right one... this device MAY require a higher current than some and low voltage could cuase the failure. Verify the adapter is the original one... if on batteries, replace them with known good ALKALINE batteries. Music devices for the most part will NOT operate reliably on rechargeables.
Aug 02, 2011 | Korg DT-10 Digital Tuner
settings.
mode.
May 18, 2011 | Korg DT-10 Digital Tuner
Our church has a Korg M50-88 synthesizer. The sustain quit working and we have tried 7 different pedals. Any suggestions?
Refer to page 222 in your PA800 user manual regarding calibrating the polarity of the damper pedal. The setting in your unit MAY have gotten clobbered.
It is NOT clear if you have a PA800 or M50-88. If you have the latter, then read page 22 of your user manual where it says in certain modes the sustain can be set to affect only certain voices. Again, see if internal parmeter settings may have been clobbered to disable the sustain.
Nov 01, 2010 | Korg Pa800 Synthesizer
Korg PA800. Ram Upgrade
The pa800 has a fixed amount of Ram at 64mbs and it is not physically possible to upgrade the Ram. The pa2x has a removable128mbs Module and that can be upgraded via a 256mb Module from Korg.
Keith [mrniceneasy - KorgForums]
Nov 13, 2009 | Korg Pa800 Synthesizer
Korg DT-10 Digital Tuner Logo
91 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
