Question about Fitness Quest Integrity 3000 Air Rower
I would like to increase the tension of my rower "Integrity 3000 Air Rower". There is an extra short Bungie cord under the slide rail, what is it used for if not to add tension to the rower?
2 Suggested Answers
SOURCE: My integrity air 3000 has a elastic like cord
Call Fitness Qwest at 800 321-9236 for the part. They will need the serial number of the machine (on the back stand underneath. All of the parts are easy to replace. It is an easy machine to work on.
Posted on Jan 03, 2010
Rowing machine belt
If there is a number printed on the belt you can search for the same number here: www.beltpalace.com/fitnessbelts.html
You may have to include the rib count if the belt has many small grooves. For a 6 rib belt, the part would look like "470J 6" or "6 PJ1070".
May 24, 2014 | Fitness Quest Integrity 3000 Air Rower
Broken cord
Where can i get a replacement cord belt for the air rower, its frayed and snapped?
Mar 31, 2014 | Fitness Quest Integrity 3000 Air Rower
I am not getting any resistance from my Integrity 3000 rower. The fan does not make a noise when I pull.
Your chain is stuck on the bearing and not on the gear. Its stuck on the rod holding the gear. See the thing that looks like a bicycle chain that leleads from the pull handle to the black cover next to the fan? Well under that black cover is a gear that holds the bicycle chain. To get to it, you need a screwdriver. Take off the cover and you need to pull the bar vertical to the air and you need to realign the chain. Your welcome! Source: same problem
Sep 17, 2011 | Fitness Quest Integrity 3000 Air Rower
How to assemble my machine
You may have to call Fitness quest to the manual for this unit
Corporate Headquarters
1400 Raff Road SW
Canton, OH 44750
Phone: 1-800-321-9236
Email: Customer Support
Fax: 1-330-479-9213 between the hours of 8:30 a.m. and 6:00 p.m eastern standard time,
Monday through Friday (excluding holidays)
Aug 14, 2010 | Fitness Quest Integrity 3000 Air Rower
The chain does not return smoothly. The chain does not retract. I don't have a manual to see if the machine is set up correctly.
A return spring or cord is not functioning or broken and the chain sprocket assembly bearing may have become defective or more likely needs lubrication. I would try contacting this company since they sold the product.Fitness Quest Corporate Headquarters
1400 Raff Road SW
Canton, OH 44750
May 20, 2010 | Fitness Quest Integrity 3000 Air Rower
My integrity air 3000 has a elastic like cord attached to the underside to the chain. The elastic cord is now unraveling. Where would I get it repaired? I live in Columbia, Missouri. Thanks, Patti O.
Jul 05, 2009 | Fitness Quest Integrity 3000 Air Rower
Where do you find replacement parts?
Can i buy a replacement return spring fr a proteus rower serial number GM013704
May 14, 2009 | Fitness Quest Integrity 3000 Air Rower
What kinds of boats are used for rowing?
The boats (or shells) are basically of two types and reflectthe two forms of rowing---sweep rowing and sculling. In sweep rowing each rower handles a single oar (about 12.5 ft or 3.9 m long) in sculling a rower uses two oars, or sculls, (each about 9.5 ft or 3 m long). The word shell is often used in reference to the boats used because the hull is only about 1/8" to 1/4" thick to make it as light as possible. These shells are also rather long and racing shells are as narrow as possible while recreational ones can be rather wide. Most shells today are made of composite materials such as carbon fiber, fiberglass, or kevlar. A few manufacturers still build wooden boats. Each rower has his back to the direction the shell is moving and power is generated using a blended sequence of the rower's legs, back and arms. The rower sits on a sliding seat with wheels on a track called the slide. Each oar is held in a U-shaped swivel (oarlock) mounted on a metal pin at the end of a rigger. The rigger is an assembly of tubes that is tightly bolted to the body of the shell.The exception to this are some european recreational boats called "inriggers" which have the oarlock attach directly on the gunwale. The subtypes of rowing shells are classified according to the number of rowers in the shell. Sweep Boats (each rower has one oar) These shells can have a coxswain---a person who steers the shell (using a rudder) and urges the rowers on. I have included in parenthesis the symbol used for each subtype along with some dimensions and weights. Coxed Pair (2+) Two sweep rowers with a coxswain. Coxless Pair (2-) Two sweep rowers without a coxswain. Coxed Four (4+) Four sweep rowers with a coxswain. Straight (or Coxless) Four (4-) Four sweep rowers without a coxswain. Steering is usually accomplished via a rudder that is attached to a cable that is connected to one of the rower's foot stretchers (this an adjustable bracket to which the rower's feet are secured). The coxless pair has a similar type of rudder setup. Eight (8+/8o) Eight sweep rowers with a coxswain. Eights are 60+ ft (~18.5 m) long and weigh about 250 pounds (~114 kg). Sculling Boats (each rower has two oars) Only in rare cases do these boats have a coxswain. Steering is generally accomplished by applying more power or pressure to the oar(s) on one side of the shell. The hands overlap (usually left over right in the US) during part of the rowing cycle, or are always left in front of right. Single (1X) One rower or sculler. Singles are about 26 ft (8 m) long and less than a foot (0.3 m) wide. Racing singles can weigh as little as 30 pounds (~13.5 kg). There are heavier (~45 to 50 pounds), shorter and wider versions often referred to as recreational singles. Double (2X) Two scullers. Most racing doubles can be also used as a pair with a different set of riggers designed for sweep oars. When used as a pair a rudder is usually added. There are also recreational versions of sculling doubles. Quadruple (4X) Four scullers. Often referred to as a `quad' and usually has a rudder attached to one of the sculler's foot stretchers as in the straight four. Most quads can also be rigged as a straight four using a different set of riggers. Octuple (8X) Eight scullers. This is rarely seen, though is used in the UK, at least, in junior competition where sweep rowing is not allowed. Weight Classifications There are basically two weight classes for rowers---heavyweight (HWT) and lightweight (LWT). Men (M) For team LWT boats, there is a 72.5 kg (~160 lbs) individual maximum, and the boat must average no more than 70 kg (~155 lbs). Women (W) The individual maximum for team LWT boats is 59 kg (~130 lbs), and the boat must average no more than 57 kg (~125 lbs). In the US, the women have an individual max only; no average. In some regattas in the US (usually head races late in the season) these limits are increased by 5 lbs. A rowing shell is usually built with a particular weight class of rower in mind. Until just recently the Olympics effectively had only HWT classifications.
Dec 01, 2008 | Sevylor Fish Ranger 280
Fitness Quest Integrity 3000 Air Rower Logo
67 people viewed this question
Top Fitness Quest Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Fitness Quest Exercise and Fitnes Expert? Answer questions, earn points and help others
