Question about Pitco Frialator Kitchen Appliances - Others
Turn the fryer on and its does not light just has a c4 code on it
C4 display by sharp sf-1025, what is the meaning of this code
Refer to documentation or manual under troubleshooting an explanation of each error code is provided resolve the error and it should work
Jun 25, 2015 | Sharp Office Equipment & Supplies
How too solve daikin error code c4
c4 error code has nothing to do with outdoor pcb. Use code 41 to check the value of the liquid line sensor and test with mulit meter. Pretty rare fault. Turn the power off for 5
Mins and reboot your system.
Nov 10, 2014 | Cfm Daikin R410a Split System Air...
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot light goes out when burner turned on
Replace the pilot generator. You are not getting the millivolts you need when you turn on the fryer.
Tom
May 28, 2010 | American Range AF45LP Deep Fryer
I have a 2 year old paloma tankles heater i get a c4 76
Make sure the wire connecting the thermostat to the unit is 18 gauge solid copper thermostat wire
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Heater shuts down with C4-13 code
your not getting enough fresh air to it. where is it located? you need 1 square inch per 1000 btu's. it's having irregular combusion.
Aug 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
The trouble light won't go off. How do i fix it?
You may have to unplug it for about 30 seconds to see if it resets. if not, I believe there is a code or sequence you can follow to turn it off. You can get this from the manufacturer.
Feb 11, 2009 | Wells F-67 21167 Deep Fryer
Kitchen Appliances - Others Logo
75 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
starztruck4u
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
