Question about MartView
MartView won't launch
It used to work fine. Haven't used it in a while, but tried today. Run As Administrator has no effect. I click Allow and get no resulting response. I uninstalled and then re-installed from MartView.com site. Windows Vista 64bit, FireFox. I'm not a computer wizard, so any response/advice would be easier to understand/follow if it includes how to do whatever I may need to do. Thanks muchly!
Not enough disk space to spool document error message when using Brother Ptouch QL-500. All other printers are working well.
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps.
Jun 06, 2011 | Brother P-Touch 2420PC Label Printer
Installed Martview to use as pdf and it will only open as admin
right click on the program and hit run as admin
Mar 15, 2011 | MartView
Is possible to click on a word in a martview file and so find the explanation on a dictionary??? Thank you
unfortunatly because Martview primarily display's PDF's, this is most likely not possible...most likely - PDF's are images and not textual files, it would be like asking the computer to read a picture and not data. However, there is a chance that a OS wide applet might be able to pick it up, its worth a try.
Try Word Web, download it (its free!) and run it, then you should be able to hold 'Ctrl' and click on anyword and it will display a definition for the word on the screen.
http://wordweb.info/free/
Let me know if this works
Cheers,
t
Mar 01, 2011 | Computers & Internet
I have the cd rom disc stratego and I am trying to install it on windows 7 and it will install but it will not let me play it.. is there somewhere where I can buy the cdrom for windows 7 or somehow that I...
This game won't work on Windows 7 in any of the compatability modes. The only way to get this game to work is to run it in windows xp. The good news is that you can get free software from Oracle called virtualbox. Using virtualbox if you have a xp installation disk, you can create a virtual windows xp that runs within your windows 7. Stratego plays fine from within a virtual windows xp, provided that you play from the cd-disk not the virtual hard drive. Install the game normally in the virtual windows xp environment. After installation, to play the game, you must be in virtual windows xp, then double click the CD/DVD drive icon that looks like a bomb. If you try playing from any of the shortcut Stratego (also looks like bombs) launchers or the stratego.exe file installed on your virtual hard drive, the game will not work.Just go to My Computer in the virtual windows xp, and double click the cd/dvd bomb icon, and the game starts up fine.
Feb 18, 2011 | Infogrames Stratego for Windows
I have a P-touch QL-500 brother label printer. When I try to print my label I get error message Not egough disk space to spool document
This solution from loquiter worked for me on my Vista PC
noavatar_s.gif loquiter
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps. .g_thread_answer { overflow:visible !important; } Was this solution helpful?
Jan 24, 2011 | Brother P-Touch 2420PC Label Printer
Dictionary does not support in pagemaker 7, i will try to custom installation with dictionary but it does not work. What i can do
This works for me.
It only works on documents that you have created by launching Pagemaker 7 (windows 7, 64 bit) as administrator (Right click on icon and choose "run as administrator". Spellcheck works for me on all such documents but not on previous documents not launched as administrator.
Nov 30, 2010 | Adobe PageMaker 7.0 for PC
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
Pagemaker spell checking problem
Pagemaker 7 will not readily allow Spell checking under Windows 7. To do this you will need to run the Pagemaker application as the Administrator. This can either be by clicking on the right hand mouse botton (right handed persons) while the cursor is on the Pagemaker launch icon either on the desktop, Windows Start up menu or Application Program launch menu and then choosing to run the Application as Administrator. Pagemake launched like this will normally allow spell checking, without  the Pagemaker application will return distionary missing or does not support spelling.
Disabling account control in Windows 7 before running the Pagemaker, which I do not recommend also achieves this in Windows 7. All the above applies for Windows Vista too!
May 06, 2009 | Adobe PageMaker 7.0 for PC
How to enable registry editing
Method 1 - Using Group Policy Editor If you are using an edition of Windows Vista (Windows Vista Business, Enterprise and Ultimate editions) which includes the Group Policy Editor, follow these steps:
  • Click Start, type gpedit.msc in the Search box, and press ENTER
  • Go to the following branch:
User Configuration | Administrative Templates | System
  • Double-click Prevent access to registry editing tools
  • Set it as Not Configured
Important: If it's already set to Not Configured, set it to Enabled and click Apply. Then repeat the steps and revert the setting back to Not Configured. This removes the registry based policy if set already.
Method 2 This method should work in all editions of Windows Vista.
  • Download reg_enable.vbs attached at the end of this article, and save it to Desktop
  • Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  • Switch to your Desktop directory by typing the following command, and then pressing ENTER:
cd /d %userprofile%\desktop
  • Then, type the following command and press ENTER
wscript.exe reg_enable.vbs
  • Type EXIT to close the Command Prompt window.
If everything worked fine, the DisableRegistryTools policy should have been removed by now. See if you're able to launch Regedit.exe now.
Dec 11, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
41 people viewed this question
Top Martview Computers & Internet Experts
David Payne
David Payne
Are you a Martview Computer and Internet Expert? Answer questions, earn points and help others
