BYTECC BT-PE2S1P Serial Adapter Logo
A
Anonymous Posted on Nov 22, 2013
Bt-pe2s driver for win 7 does not install - BYTECC BT-PE2S1P Serial Adapter
10helpful
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
1helpful
Hi, i have a msi cr420 windows 7 starter os and i cant use my bluetooth, do i need to download a bluetooth driver?
Johan, If the BT is an add on dongle then you do need a driver for it, while if it is inbuilt and the laptop came with Win 7 as operating system then you need to find the BT icon in Control Panel and re configure it. Please do that.
I have a BYTECC BT-PCI-SATA 150 I/O controller card but it does not work with windows 7. Is there a driver available for this model?
I can't seem to find a product with the model number "BT-PCI-SATA" that you provided, on the Bytecc web site. You should shut off and open the computer and read the model info directly from the the I/O card to determine the exact model card you've got.
Once you which card you have, you can download drivers directly from Bytecc. There appears to be very limited support listed for both Vista & Windows 7 OSes however. If nothing else, you'll be able to download the latest version of the driver - that may support Windows 7 - without specifically stating that it does.
If you're trying to install Win 7 to boot from a hard drive connected to this controller, it may work if you supply the expanded driver on USB, floppy, etc. when prompted for a SATA driver. Bytecc only offers an email address for tech support, so you might want to send them a detailed note about the problem at: [email protected]
Hopefully, this helped - good luck!
2helpful
Where can I get a driver for a Xerox WorkCentre XD155df (laser printer/copier) for a 64-bit Windows 7 operating system. The Xerox web site says it does not have the driver and doesn't support the product...
you wont get a win 7 64bt driver!! they havent and will not develop one.. You can use the XP 64bt driver and install it manually in win 7 .. :) yeah a neat trick here is how.. download and unzip xp 64 bt driver files to a folder called FX on your desktop
  • plug printer into pc it will say new hardware found,,
  • wait for the wizard to finish and fail..
  • click start, right click computer, click properties then device manager
  • your printer will be there highlighted in yellow,, right click and select update driver,,
  • click searh a specific location and browse to the FX folder on the desktop.. click next and watch the magic..
  • if it says driver not supported (contine / cancel) click continue and accept the warning message..
thats it... Amazingly win 7 accepts vista and xp drivers in this manner..
Hawking HWU8DD Vista Driver crashing Win 7. I just purchased new desktop running Win 7. Old system ran on XP. XP Driver would not work. Installed XP driver. System runs for ~10 minutes and crashes...
there will be no win 7 driver as win 7 is no longer supported by Microsoft
to get a driver , you have to go to the manufacturers web site , find a down load for that model that is compatible for win 7 operating system
win xp is also not supported by Microsoft so there will be driver problems there as well
2answers
I am trying to install my printer the software is
HI there
you will need the new software for win 7 , and it not easy to find the new drivers for the printers to mach
Ei-3103 vista drivers needed
download AC97 sound driver for vista and realtech ethernet driver for vista these are the to most common,  and install them
Top BYTECC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
