Question about Techni-Brew International Home
Pumps very little at time takes several pumps to get a cup full
Floor Jack 6ton
Mine periodically won\'t run and I have to clean out the pump. The water exit pump/line has cup with holes in it that serves as a filter to prevent object going thru the pump. The little cup on mine fills up with coins, restricts enough water flow, and the washer will no longer run. Take off the access panel below the door to get to it - the pump/hoses are to the right side. There are either 2 or 3 hose clamps that have to be removed to separate the hose connections from the pump - pain to get to, But with the hoses off, the cup is easily cleaned out. I replaced one of the stock clamps with a plain old band clamp you tighten with a screw driver - much easier when putting it all back together. Hope this helps...
Jun 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
My Keurig B60 has started making a grinding noise and takes along time to brew eash cup. Why is this happening?
My Keurig was making louder than usual noises like the pump was straining and took twice as long to make and was not filling the small or large cups to there expected capacities. I did a descale with white ninegar even though it was not registering to do so and still no change. But when I cleaned out the screen where the tank plugs in, there were alot of smal obstructions. I used several dry q-tips to pull the obstuctions(lint,etc.) out and now it works like a champ. I also used a small straightened paper clip to clear out the upper and lower k-cup needles becasue there were obstructions there as well. Now it is as quiet as it was brand new and makes FULL small and large cups!
Jan 05, 2011 | Keurig B60 Coffee Maker
My Keurig B60 is suddenly not dispensing water when a K-cup is in the machine. Dispenses fine with no cup in chamber.
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
Dec 03, 2008 | Keurig B60 Coffee Maker
Keurig Coffee maker not taking in water
Mine started off that way, then quit pumping any water through the K-cup. I overcame the problem with a reusable K-cup. If it will run a full cup through without the K-cup in place, this will probably work for you. They are available online and at some national chain stores for about $15.00. It's a little more inconvenient than K-cups, but better than throwing out a $150 coffee maker.
Jul 23, 2008 | Keurig B50 Coffee Maker
Baby gaggia wont pump
The pump may only have lost its prime. To prime the pump:
Fill an ear syringe (available at most pharmacies) with water. Insert the business end of the syringe securely in the tube that normally takes up water from the reservoir. As you squeeze the syringe bulb, flip the brew switch on. If you see movement of water in the tube, and hear a change in the sound the pump is making, flip the brew switch off, remove the syringe, and put the tube back in the filled reservoir. Now flip the brew switch on, and see if the pump can draw water on its own. Repeat several times if necessary. If the pump still won't pull water, then it must be replaced.
www.espressosolamente.com
Apr 21, 2008 | Gaggia Baby Espresso Machine
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Home Logo
709 people viewed this question
Top Techni-Brew International Home Experts
Donni Steen
Tom Chichester
Are you a Techni-Brew International Home Expert? Answer questions, earn points and help others
