Question about Kyocera Km 3060 Digital Copier With Print,scan With Only 90k
How do you keep people from being able to use the maintenance key on kyocera km3060
  • 52 Answers
Change the admin password on it. Or if not feasible, then put a sticky label over the button.
Posted on Nov 26, 2013
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
Kyocera maintenance kit reset
You can access the following by hitting the menu key
1. Enter the maintenance mode [>>Maintenance].
2. Press the OK key. [>>Maintenance?] will be displayed.
3. Press the OK key twice. The counter for each component is reset immediately.
Aug 26, 2014 | Kyocera FS-1370DN
Maintenance light blinks
Enter "10871087" using
the numeric keys
Enter the U251 number using numeric keys.
Press the copy start key.
Select the Light exp. 3. using the exposure adjustment keys.
The count is cleared, and the indication for selecting a maintenance item No. appears.
Apr 30, 2014 | Kyocera Copystar CS-1635 Copier
Kyocera
Hi Ben
Sounds like the roller that pulls the paper through has maybe lost teeth on the roller itself.
1702F33E20 Kyocera Genuine MK 510 Maintenance Kit
Jan 09, 2014 | Kyocera FS-2100DN Laser Printer - FS2100DN
Kyocera 1018 me sale error c6400
Zero-crossing signal problem
• The engine board (KP-5238) does not
detect the zero-crossing signal for the
time specified below.
At power-on: 3 s
Others: 5 s
Usually something wrong with electricity..
Try to clear this error:
Enter maintenance mode:
1. Press the system menu/counter key.
2. Select "Service setting" using
the up/down cursor keys.
3. While pressing the start key and the # key,
press the enter key.
4. Select "Maintenance mode" using
5. Press the enter key.
6. Enter the maintenance item
number using the up/down keys.
You need maintenance item 163
1. Press the enter key. A selection item appears.
2. Select "Execute" using the up/down cursor keys.
3. Press the enter key. The fixing problem data is initialized.
May 20, 2011 | Kyocera Mita LaserPrinter FS-1018MFP...
How to reset maintenance time kyocera copier cs-2560 ,
the numeric keys.
enter U251 Checking/clearing the maintenance count
reset it to 0
# to enter i think
Oct 09, 2010 | Kyocera Copystar CS-2560 Black and White...
Kyocera FS1118, error code C6400, how do I resolve This?
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Jun 21, 2010 | Kyocera FS-1118 Printer
How to reset maintance call on kyocera km-1635?
10871087 then 251 then hash key then set it to 0 or cancel to reset the counter
Mar 15, 2010 | Office Equipment & Supplies
Kyocera Km 3060 Digital Copier With Print,scan With Only 90k Logo
76 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
