Replace motherboard need to completely remove and replacce the motherboard
  • christopher
    christopher Nov 23, 2013
    Thanks everyone for your input. I determined the problem already to be the motherboard and you are correct. I will get F***e* if i try to replace it. In addition, this model all in one does not have video outputs. HP really screwed folks on these. I am going to scrap the system and salvage the usable parts.
    Top Expert:
  • Computers & ... Master
  • 22,801 Answers
What is the make and model? Be sure you purchase the correct replacement with the same suffix otherwise your chip set will not match your drivers.
Posted on Nov 22, 2013
  • 28 Answers
I've little experience at doing this with a laptop but for a desktop it's easy enough. The key thing is to make sure that you get a motherboard that fits the case you're using, that has the correct socket for your cpu and has the correct sockets for your RAM and other components, such as the hard drive, disk drive etc.
I would recommend doing several things before you start. First back up all files you want to keep and export all settings you want to keep onto external storage. Phone your operating system provider and make sure that switching the motherboard will not void your copy of their OS. Make sure you have a completely clean workspace and get yourself an unused, clean microfibre cloth and some thermal paste.
Ensure you have an appropriate sized screwdriver and that you know how to unclip the various external panels, I imagine this might be quite tricky on a laptop.
Next copy the chipset drivers for the new motherboard onto your pc so that they are ready to use. It's possible you may get away without running a clean install but frankly unlikely. Get all your driver and software discs ready and make sure you know all your online passwords and have your CD keys available.
Once you get started make sure you've given yourself plenty of time, largely for reinstalling software. I would suggest powering down the laptop and removing the battery the night before you intend to make the switch.
When you get started be sure to begin by earthing the motherboard, gently, you don't want to scratch anything. Next do a visual check just to make sure you do have a motherboard that will fit into the space and that uses all the same connections. Something as simple as the ports being in different places may mean that once assembled the laptop will not go back together again.
Carefully detach the power supply from each component and remove any parts that prevent you from easily removing the motherboard. Once the motherboard is out the first thing you will likely want to do is gently remove the heatsink for the cpu and the cpu. Clean the connecting surfaces of both parts from any of the old thermal paste with the dry microfibre cloth. Once the surface is clean you can apply a smooth layer to the base of the heat sink. When you connect the cpu and then the heatsink to the new motherboard remove any excess paste from around the edges.
Depending on which parts are where depends on what you'll want to reconnect first/last. The one issue I've most frequently come accross is ensuring the RAM is properly in place. It should be fairly apparent which way round it goes and if you refer to the manual that comes with the board it will tell you the order in which the slots should be filled/paired (not always intuitive) but even when it appears to be in place securely it can be slightly out, so when you but this in place make sure that it is pushed in firmly, without being aggressive.
When connecting everything back up remember that their may be more than one power supply to the motherboard and that the hdd and disc drives will also need power supplies as well as connections to the motherboard.
Once everything is back together plug it in and see how it goes. You may be lucky and things will come back up fine but more likely you will need to be ready to run a clean install.
Not something I do that regularly so hope I haven't missed any major parts, and again, not something I've ever done with a laptop.
Best of Luck
Testimonial: "Thank you for your input. The fixya dialog box did not record all of my query. The problem I have was with removing the MB, it seems to be attached to the monitor and I wanted advice before I forced it loose. I determined the problem to be the MB and the it will be too expensive to replace. I will recycle the parts that are of no use and keep the Fan, CPU, HD, DVD drive and RAM"
Phone numbe for tupperware for replacement lids
To request a replacement part: Contact your Tupperware Consultant or call Customer Care at 1-800-TUPPERWARE (1-800-887-7379). To expedite your call, locate the mold number on the product prior to contacting your Tupperware Consultant or Customer Care.
Replacement Parts
May 15, 2017 | Food Processors
How to get to the alternator
I am told you are no longer supposed to check your alternator with that method due to putting your PCM at risk. Better to check voltage at battery before and after starting. The book method of alternator access is to remove the right side axle.
Feb 16, 2013 | 2005 Ford Escape
My nokia n95 strip problem,display not working
You will need to replacce the strip after procuring the same type from the Nokai centre. But I would advice that the strip be replaced at Nokia care,.
Oct 27, 2010 | Nokia N95 Cellular Phone
Unit indicates voltage but oven produces no heat
Might have to look for the series fuse to the magnetron, if blown and on replaccement if this blows again the magnetron is faulty and needs a replacement.
If this seems OK , the high voltage capacitor can be weak or open or short. replace and the microwave will work.
Finally check the door switch the temperatrue cut off unit , the main relay and the control board.
Sep 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
E71 mic problem
dear this is what we call it a digital mic that assembled on the board so you can't just replace it.
you have to take it to service center to replacce it for you.
hope it works for you
Apr 24, 2010 | Nokia E71 Smartphone
Misfire in #7 cylinder. think i need to change the plugs. don't know how.
This is what I do when I have a miss on one cylinder with a coil-on-plug ignition system: Take the coil off of the suspect cylinder, and remove the plug. If you see no obvious problems with these 2 parts, swap each with another in a different cylinder, paying close attention to where you moved them to. For example: move #7 plug to #5, and #7 coil to #3. Now run the engine and see which cylinder has the misfire. If it moved to #3, you have a bad coil. If it moved to #5, the plug is bad - replace them all unless they are very new. To replacce the plugs, remove each coil and you can access the plug beneath with a standard spark plug socket and extension. Good luck!
Jun 28, 2009 | 2000 Ford Expedition
Need to replace motherboard on hp dv5163d
HP.com has complete remove/replace procedures with pictures in their free manuals downloads that would be better for you than me just writing. Do go slow and keep track of all of the screws as they vary in length and remove all modules first. If you need further assistance once you have the manual to follow then please repost.Good luck, Steve
Dec 10, 2008 | Computers & Internet
IBM Thinkpad T42 doesn't power up
moherboard failure I am sorry but al these descritions are descriptive of bad motherboards you can find good replaccements for them on ebay
Nov 23, 2008 | IBM ThinkPad T42 Notebook
M925 Motherboard On this motherboard it does not specify where to attach pwr switch, rest switch...etc....ant suggestions? I am replaccing a bad motherboard.
The closest I could come up with is the m900 on the ECS site which is horribly unfriendly. but here's a link to the manual for that board. something as common as thos plugs should be the same across the entiore model series. Hope this helps.
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=822&DetailName=Manual&MenuID=44&LanID=9
Jul 09, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
