Question about Maytag Neptune Washer Door Mah3000aww
Maytag Neptune Tripping circuit breaker midcycle
Washer seems to start and fill okay but when it goes to spin it trips the circuit breaker. Any idea of cause?
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 517 Answers
This looks like it may be your wash heater or your motor
if you take off your motor lead from motor if it still trips ???????? then look at the heater it wants to be replaced
Posted on Jan 01, 2014
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
My Maytag Neptune washer wont start circuit breaker tripping and I got a flash from indside the washer i am an electrician who is very good at trouble shooting of electrical circuits but I do not have any...
Inside or on the back there is a schmatic with trouble shooting guide. remove top panel and look for burnt spots. most common issues would be broken/cut wire or bad board
Mar 23, 2011 | Maytag Neptune MAH9700 Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer trips circuit breaker during spin cycle
try unplugging the motor then put onto spin it will pump out ok and run othewise spin if all else is fine ,next reconnect the motor if it trips again then motor ' fault; repair /replace.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Put washing machine on and it automatically trips
If it is tripping the breaker, the first question that has to be asked is how many other appliances do you have on the same circuit. When the washer goes to spin it will start to draw slightly more electricity than once its at a full spin(much like the energy needed to get a car moving is greater than once it is up to speed), but it is not enough to trip the circuit unless there the circuit is already near capacity.
Before attempting to check electric of the washer, check and remove items from the circuit. To know what circuit runs your washer you will need to take a pigtail or a radio and plug it into the outlet Go to circuit breaker box and turn on and off circuits until the radio goes out.. Once you acertain what circuit your washer is own, go throughout the house and see what circuts are shared with the washer. Unplug any that are shared with washer. Your Hotpoint needs no more than 15 amps to run but if your overloaded on the circuit, the spin is enough for it to trip the circuit. Try washer and see if you go through the full cycle.
Oct 13, 2009 | Hotpoint Washing Machines
Gfi installed yesterday on washer 120 v outlet. washer is maytag 3 years old and gfi began tripping during washcycle. can it be washer 3 pronged cord is not grounded at connection in rear of washer?...
The ground not being connected does not tirp thr gfi. The gfi senses the current between the two legs it will trip when the current returning to ground (neutral) exceeds 5mili amps. This is for personal protection. If you have a gfi circuit breaker disconnect the black wire from the breaker, if it does not trip you likely have a groung fault in the washer. If you have a dryer or other metal object that is grounded (Bonded) you may get a shock from it, also standing (barefoot) on a concrete floor may cause the same. ( bonded is a gronded conductor that attaches all metal parts of a electrical curcuit together) a hot lead goes to ground is a dead short and will trip any breaker.
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Sep 04, 2006 | Maytag LAT2600A Top Load Washer
Maytag Neptune Washer Door Mah3000aww Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
