Question about Kyocera FS Office Equipment & Supplies
Error code 6000...i replaced fuser unit but code still remains
  • james macdonald
    james macdonald Nov 25, 2013
    more detail... My Kyocera Ecosys FS-4020DN printer gave the 'call for service' with the 6000 error code. I read the description of the problem, it sounds as is decribed, that the issue is with the Fuser itself. I replaced the fuser, still the error code remains. I also checked the connector for continuity from the front of the connector to where the wires seem to end and all was good. What to check next?!? Is the PWB defective? how can I check?
  • james macdonald
  • Kyocera Expert
  • 337 Answers
The code may have to be reset from the service mode
Posted on Nov 30, 2013
4 Suggested Answers
SOURCE: How to correct an error E000?
Try the following:
1) Press Additional Functions
2) Press # to enter the service menu
3) Scroll over to select "#12 Clear" and press Set
4) Scroll over to select either "ERR" or "ALL" and press Set
5) The LCD should report "CLEAR OK". Cycle power on the device.
If the error returns the device may need service.
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
SOURCE: Replace Fuser Reset
For the MFC 8860, I turned off the printer. I help down menu. I turned on the computer. It entered Maintenance mode. I typed in 88 (Parts Replacement.) I scrolled to the fuser, clicked ok. Then, I turned off the printer. When I turned the printer on, it said that I needed to replace my laser. I then turned the printer off, help down menu, turned the printer on, typed in 88 at the maintenance menu (parts replacement), scrolled down to laser, and hit ok. I then turned the printer on and off, and poof, now it works. I find it quite unscrupulous that I had a replace PF Kit1, replace Fuser, and replace laser messages all within one hour...
Posted on Dec 15, 2008
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
How do I fix a 3 in 1 printer Utax CD 1316 giving printer Error 6000
Error 6000 is fuser related.
Broken fuser lamp error
=bad thermistor
=broken thermal cutout
=bad fuser lamp
check these items, if possible replace fuser unit.
Jan 07, 2015 | Kyocera Mita Utax Cd-1316 Compatible...
What does this error code mean 6000:0185578
Error code 6000 is usually a Fuser unit error. You need to replace the fuser Unit.
Aug 19, 2014 | Kyocera FS2000DN Laser Printer
Il affiche printer error service call6000
problem is with fuser,Code Error indications Contents
Check procedures/corrective measures
6000 Fuser unit error
Yes
Yes
Yes
No
No
Turn power switch off,
and remove power
cable.
Detach connector CN4
on power supply unit.
Detach connector CN1
Measure resistance
between pins 1 and 2
of the detached
connector.
Replace fuser thermistor.
See page 1-6-25.
Replace thermal cutout or
heater lamp. See page 1-6-
26 or 1-6-22.
Replace bias PWB (K0009)
or high voltage unit or power
supply unit. See page 1-6-13
or 1-6-12.
Open (infinite)?
No
No
Open (infinite)?
Measure resistance
between pins 1 and 3
of the detached
connector.
Replace harness
(2FM2601) between engine
PWB (K0010) and bias
PWB (K0009).
End.
Yes
No
Replace engine PWB
(K0010). See page 1-
6-9.
"6000" error
shown?
"6000" error
shown?
START
Feb 03, 2014 | Kyocera Mita Fs-1016 Mfp Multifunction;...
Kyocera fs-4020dn; Error code 6000
Be sure to power down and disconnect the power first.
A fuse it is blown within the fuser unit - replace that fuse or call a technician to do it for you.
Nov 25, 2013 | Kyocera FS Office Equipment & Supplies
Kyocera FS-2000D error 6000:0087166
This Code relates o the fuser unit, needs to be replace but if this code keep coming constantly from time to time than you need to check this:
There is a two wire power connector from the switching regulator ( by the interlock switch ) that goes to the fuser connector. This is one of the areas we check for the 6000 error code.
You could also check for a small piece of paper lodged in the fuser connector, both on the fuser and the one at the engine board.
also Check the power at the wall outket. Low power will cause 6000 errors.
Nov 10, 2011 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D and an error 6000:0087166 what can I do...???
Error Code 6000 is fuser code, you need to replace the fuser unit, make sure there is no paper stucking there first!
Service code c 6000 comes up what do we do? 314 308 5296
fuser error..nothing you can do but replace the fuser unit..
Jan 25, 2010 | Kyocera Copystar CS-1820 Black and White...
What do you mean by error c6000 in KM4050?
Error code c-6000 means fuser error. It would be best to replace the fuser unit as a complete assembly, but sometimes just the thermostat can be replaced, which would be cheaper. Either way, an authorized Kyocera dealer should have these parts.
Nov 12, 2009 | Kyocera Copystar CS-1820 Black and White...
81 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
