Light 1 and 2 off lights 3 and 4 on
Lights 1 and 2 off lights 3 and 4 on
    Genius:
  • 1,479 Answers
Does this question question relate to anything in particular or do we have to guess. So many possibilities.
Posted on Nov 22, 2013
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
I installed a flatbed on my 94 ranger. I installed new tailingts on unit with 3 wires on lights. How do I wire (1) left signal (1) light (1) brake light (1) backup light to 3 wires on tail light. Of...
I belive the signals and brake light are the same hook up, think about it, when the signals are flashing it is the same filiment in the bulb that works them,
Apr 05, 2011 | Ford Ranger Cars & Trucks
Need wiring for 4 light with 4(2 way switch) when on 1 switch 1 and 2 light will on when on 2 switch 1 light will off 2 and 3 light will on when on 3 switch 2 will off 3 and 4 light will on when 4 on...
i don't know about 2way switches but a three way switch that will turn a light on at both ends of a hall or off is power to one switch ,three wire between switch switch leg from other switch , make up is tie neutrals together grounds together leaving a black and red from tree wire (travelers)and a black at the switch leg (power)
Sep 24, 2010 | Home Fencing
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
My xbox box has 3 red lights flashing... i know there are different types of error how do i know which on i have?
after turning it on, and seeing it display 3 red lights, hold the sync up button and tap eject.
The lights will change to a different pattern. This represents a number.
The number is four digits, so you'll have to hold sync and tap eject FOUR TIMES, remembering each pattern.
Pattern numbers are as follows:
4 red lights = 0
3 red lights = 3
2 red lights = 2
1 red lights = 1
Most common ones are 0020 and 0120.
Jul 17, 2009 | Microsoft Xbox 360 Console
Flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
Oct 25, 2007 | Indesit W 123 Front Load Washer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
