Question about Fossil FS4318 Watch
Battery what is the battery size?
Battery size for kenneth Cole watch 4982
Renata brand battery size / number 377
Mexell brand battery size 626
Oct 11, 2016 | Kenneth Cole Watches
Fossil fs4141 battery size
  • Remove back
  • Find battery location. Note mounting arrangement for later new battery installation
  • Identify battery type (not size)
  • Obtain replacement battery
  • Install in correct position with correct polarity
  • Check operation
  • Install back
  • Set time, etc.
Sep 12, 2016 | Fossil Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
What size of battery fits guess steel
Just take it to a local jeweller and they will change the battery whilst you wait for $6 to $8. There are so many batteries and usually you can't by just a single one in the small sizes that watches use.
You often need a special tool to get the back off, and a jeweller's eyeglass to see the tiny screw and the right screwdriver to fit it.
May 20, 2016 | Guess Waterpro Bracelet Watch
What type of battery fits my watch?
The battery size may be stamped on the back of the watch. Jewelry counters that sell batteries will determine the size and even change it for you. If you are a bit mechanical you can remove the back, mine has little screws but often it is one you pry open with a thin screw driver. You will then see the battery but don't move it until you make note which side is up. The size is stamped on it. Put the new battery in facing the way the old one was and close the cover.
Apr 27, 2015 | Watches
Replacement battery size for ar5303
it battery size 371/370
May 27, 2012 | Watches
What size battery do i need for this watch ?
there are two batteries inside your watch one is for analog sr621 size of battery and the other one is for the digital cr2016 size of battery, i hope this will help you.
Sep 25, 2011 | Fossil Big Tic watch #BG1006 Watch for Men
WHAT SIZE BATTERY DOES THIS TAKE
mcdevito75 here, Each watch is slightly different, although 371 or 364 may be the battery size.
Sep 24, 2010 | Kenneth Cole KC2437 (Size: ) Watch for...
What size battery does this watch use?? I threw
the battery type should be written either on the inside or outside of the cover, or google up that model watch and find out online
Aug 12, 2009 | Colibri PWL-90045 Pendant Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossil FS4318 Watch Logo
20 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
