Question about Coffee Makers & Espresso Machines
Hi all!I bought a second hand saeco royal digital and I have a problem!when I push the button to make me a coffee, beside the coffee is also getting out hot water and steam from that little tube especially made for that.I'm afraid something isn't right!it is not possible to press the coffee button and at the same time to get coffee and hot water and steam.what can be the problem?please help me to fix it!
  • 2039 Answers
SOURCE: Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Posted on Jan 15, 2008
  • 67 Answers
SOURCE: no hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Posted on Jan 19, 2008
SOURCE: Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Posted on Jul 01, 2008
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
EsWorld
  • 1618 Answers
SOURCE: No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Posted on Oct 07, 2009
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
I have a Saeco Royal Professional at work and when each of the three coffee size buttons are pressed you get three different sized coffees. I have just bought a new Saeco Royal professional for home and...
Hi
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Apr 05, 2011 | Saeco Royal Professional Espresso Machine
My Saeco royal coffee machine is making a very short expresso even when you push medium size. Is there a button to adjust to get the lenght you desire?
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn't fix it, then you might need a new flow meter.
Sep 22, 2010 | Saeco Royal Coffee Bar Coffee Maker,...
Saeco royal digital plus how to ventilate
Hi
Push the button with the water drops on it.
Jun 14, 2010 | Saeco Royal Digital Plus Coffee...
I can't figure out how to make regular coffee (not espresso) in a SAECO Royal machine. Any recommendations?
Hi There are 3 buttons for making coffee. Try programming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Feb 15, 2010 | Saeco Royal Professional Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
How to decalcify royal digital?
hi my name is Lee Davidian here is your answer
Automatic Decalcifying Cycle
The automatic decalcifying cycle keeps the machine in perfect operating order. When prompted by the user, mineral buildups in the internal boiler can be dissolved and removed with Saeco’s decalcifying solution and a push of a button.
Jan 11, 2010 | Saeco Royal Digital Plus Coffee...
How do I check how many coffees we have made on our Saeco Royal Professional coffee machine
Hi
Push and hold the menu button. When is says "energy saving" use the up arrow and go up about 3 or 4 pushes until you get the * beside the "total coffee", then push the menu button again. The menu button is what gets you into the selections and is what locks changes in the computer.
Oct 06, 2009 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
