Tape drive doesn't turn, clicking noise then error message
SOURCE: Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
SOURCE: belt replacement in a sony tc-wr645s tape deck
I have just spent half a day trying to replace the drive belts in my sony twin deck unit , in the end it still didnt work as the the old rubber belt did some damage to the unit , anyway shops like **** smith or tandy stock the drive belts , take the front of the unit away from the main case there will be a plastic casing that surrounds the belts there are at least two belts, there should only be two small screws undo these and move the plastic unit forward on the plastic mounting brackets then you will see the metal wheel and the plastic wheel that you fit the belt around , its a bit fiddly but i can do it in my sleep now even though the motor died it was a good experience
SOURCE: Sony tc-wr535 won't eject. Tape stuck. Won't play
The problem, according to messages on your site, is that the belts are old and have stretched. There is a great step by step tutorial on www.Instructables.com with pictures and all. Parts are not too hard to find on search engine. Looks like less than $25 to fix.
http://www.instructables.com/id/How_to_replace_the_belts_on_a_Sony_TC_WR535_Dual_C/
