Question about Haier CPN10XC9 Air Conditioner
Heat not working on the CPN10XC9 - Haier CPN10XC9 Air Conditioner
Have not used my unit for 5 years and I notice a funny smell.How do I deodorize or clean it?Model #CPN10XC9
There are evaporator coil cleaners that have a pretty good scent. And some have a disinfectant for mildew. Hardware stores carry it or any a/c or refrigeration parts houses. Ask for EVAPORATOR NO RINSE. It's an aerosol that washes away with the condensate. And the insulation is a bit tougher to clean. There are also ODOR CAKES they use on smoke damaged homes at the parts house. They may call them something else. Just open it and lay it in the return air somewhere.
Jul 01, 2015 | Heating & Cooling
Heater, ac and fan speeds all working fine. Compressor not kicking in...just auxiliary heat working.
Outside temp too low, so outside thermostat and it's settings will not allow the heat pump to work. But insist on the ausilary heat to work instead. Heat pumps usually do not produce enough heat when below 40F outside temp. If you have Gas heat, it may be more economical than the heat pump below 40F. If electric auxilarry heat, it may compete at 32F. Talk to your dealer, installer, or manufacture.
Mar 04, 2015 | Amana PTH123B25AJ Heat Pump Air...
I have an air conditioner portable Model: CPN10XC9, and have a problem, when I plug it into the wall outlet will not turn on and the screen lights E1. I clean the filter as the manual says and yet the E1...
I dont know what the E1 stands for but make sure that if its on an extension cord that its rated for appliance use and you might try another outlet. Sometimes the load from an a/c is great enough that the receptacle overheats and causes the problem.
Aug 17, 2013 | Haier CPN10XC9 Air Conditioner
Stops working
you forgot to plug it on the power outlet.
Jun 03, 2013 | Haier CPN10XC9 Air Conditioner
Problem with Haier CPN10XC9 Portable Air Conditioner: water accumulates around bottom of filter area
Samsung E163 EEPROM option error? Program the right option codes!! In my case the complete airconditioning installation (3 x indoor and 1 x outdoor unit) didn't work because the E163 code was showed on one of the indoor unit. After I followed the procedure (remove batt from remote control, put them in again holding down the right knobs, etc see the manuals you can find on the internet) I programmed the right codes within 5 minutes and the problem was fixed, the error code was gone and the complete installation was working again. So don't replace boards, electronics etc....just put in de right option codes. John, Netherlands.
May 27, 2012 | Heating & Cooling
All of a sudden it stopped working. The display now only blinks STOP. I tried unplugging it, resetting it, pushing the on/off button. Nothing happens, it just keeps flashing STOP. Very frustrating
I had the same problem until i opened the drain and got it nice and clear. Pushed the reset button and now it works, hopefully thats what fixes your problem.
Jul 15, 2011 | Haier CPN10XC9 Air Conditioner
Haier CPN10XC9 leaking water. Have drained the
I had the same problem, removed rear cover (15 screws) and found a drain slot under the conderser plugged with dust and grime. gently cleaned the slotted area out with a Q-tip, and the condensate is now following the proper flow into the tan and evaporator. It has been running for 2 hours with no drips!!
Jul 17, 2010 | Haier CPN10XC9 Air Conditioner
Haier CPN10XC9 Air Conditioner Logo
15 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
