Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Buy new icemaker - Frigidaire FRS3R5EMB Side by Side Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon aliceboyer, thank you for your post!
I am happy to assist you! Are you seeking information on where you may purchase a new ice maker? Do you need the part number? With this data I can provide the correct information to you. Thank you!
Posted on Nov 25, 2013
How do you remove icemaker to check if water tube is frozen?
the ice maker is finished. get the ice maker model number and refrgerator model number and buy/ install a new one. It would be a good idea to replace the electric water valve to the ice maker as well.
Feb 07, 2014 | KitchenAid Architect Series II KSRJ25FXMS...
Frigidaire refridgerator leaking in icemaker
Try buying a new ice maker kit and replace it by doing it yourself. This would help you in saving money.
I recently bought a ice maker kit at lower price from Partsimple.com. they delivered it faster compare to others available in market and that too at low cost. Isn't that Good?
Try searching with compatible model no on Partsimple website.
Feb 11, 2013 | Frigidaire Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Lg side by side model number lrsc23915sw ,ice maker shut off arm only moves only about one half inch upword,front of arm attached to curved plastic piece this model was bought in canada
the icemaker arm on the L g are diferent dont try to pull up not a shut off arm this has a switch under side of ice maker if u kift up on the arm on this icemaker yo uwill need to buy a new icemaker and they arent cheap check for an ice jam between auger in icemaker if you havent pulled up on arm ive also seen the water fill tube to icemaker frozen
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
My LG frig icemaker stopped making ice. Water is still coming out of the dispenser. What could be the problem?
Your icemaker is stuck in the heat mode. Which means you need to buy a new one. Sorry. Rate me.
Aug 26, 2010 | LG Refrigerators
Icemaker stopped producing ice
Your ice maker can be rebuilt. I would disconnect it from the plug and remove it and carefully take it apart. Be careful not to loose the lever arm spring as you disassemble. Look at it once the screws ar removed under the front cover. It is rare to have a defective new water control valve. But once the ice maker is unplugged you will know because the ice maker is what tells the water to come on once the cube rake reaches home position. Sometimes the thermostat that tell the water on is stuck or the micro switch that tells the heater below the ice maker to remain on causing the same symptoms. So it will be most likely the ice maker and less likely the water control valve. The parts are priced so high it is cheaper to buy new than to buy parts. But I have fixed them without replacing parts. Sometimes the micro-switches just get stuck. What to rebuild it and me help you? Sea Breeze
Apr 11, 2010 | Whirlpool ED2FHEXN Side by Side...
I have a 15 year old GE fridge with an icemaker that has started
You can buy a new icemaker from Home Depot your is probably rotted. Unplug the appliance and unplug the icemaker then remove the screws.
Sep 24, 2009 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
